A soap bubble is an extremely thin film of soapy water enclosing air that forms a hollow sphere with an iridescent surface.
What fluid dynamical process occurs during the popping of a soap bubble?
A bubble, while it still exists, is balanced by three factors:
1) Surface Tension of the soapy water.
2) Internal Pressure applied by the air inside the bubble on the surface.
3) Atmospheric Pressure.
When any of these are imbalanced, one force is greater than the others and this causes the bubble to pop.
If you're talking about why do they burst in practice? Well the bubble's surface is made out of soap water. Soap is lighter than water so when you create a bubble, the water is pulled towards the bottom of the bubble - pushing the soap upwards - due to gravity. Surface tension of water is higher than that of soap, so the upper part of the bubble is getting weaker as more soap is concentrated at the top. Soon, the internal pressure will be enough to break the bubble, causing it to burst.
Another reason is that the water gets evaporated, leaving it with a more concentrated solution of soap which - as mentioned above - has a lower surface tension.
A bubble always behaves on the principles of "Bubble dynamics". These are governed by the Rayleigh-Plesset equation. As outlined by @mikhailcazi;
the 3 pressures are integral in the behaviour of the bubble. Yet, the bubble doesn't pop immediately when internal pressures increase (Brennen explains this excellently). There are phenomena such as bubble growth and collapse as well. You might look into that if you are studying the soap-bubble in detail, and wish to use the Lagrangian approach for the same. Some assumptions for the Rayleigh-Plesset equation which you need to remember:
And to answer your question;
It is basically the pressure variations that occur inside the bubble due to the external (ambient) pressure variations. The surface tension force adjusts by the change in radius that occurs due to expansion/contraction of the bubble; and balances the pressures till the soap film becomes too thin.
Question number 1: A soap bubble is black when it bursts, why?
Answer: When a soap bubble bursts, it looks black due to destructive interference. When a bubble bursts,
If you look to Slow-Motion you will find the popping of a soap bubble is a kind of chain reaction, i would guess that bubble system may not be able to reach a lower energy state by releasing energy into the enviroment. so a reaction results in a small energy release but making way for more energy releases as a chain process. then the bubble system will typically collapse.
