Consider the scalar field transition amplitude $$\tag{1} \mathcal{A} = \int_{\phi_i}^{\phi_f} D\phi e^{iS[\phi]/\hbar}. $$
Let $\phi_{cl}$ solve the classical equation $\frac{\delta S}{\delta\phi}=0$. Denote the stationary phase approximation to (1) by $$ \tag{2} \mathcal{A}^{SP} = e^{iS[\phi_{cl}]/\hbar}\left({\det \frac{S''(\phi_{cl})}{2\pi i \hbar}}\right)^{-1/2}.$$
Denote the tree-level contribution (i.e. sum of all Feynman diagrams with no loops) by $A^{tree}$.
Does $$\mathcal{A}^{SP}=\mathcal{A}^{tree}~?\tag{3}$$
Note: I'm fairly sure the equality holds in the case of a free theory, since then the stationary phase approximation is exact, and there are no loop diagrams. I'm interested in whether it holds in general.
  1. We cannot resist the temptation to include a bulk source $J$. The transition amplitude/overlap is $$\begin{align} \exp&\left\{\frac{i}{\hbar}W^c_{fi}[J]\right\}\cr ~=~& Z_{fi}[J]~=~\langle \phi_f,t_f|\phi_i,t_i\rangle_J\cr ~=~&\int_{\phi(t_i)=\phi_i}^{\phi(t_f)=\phi_f} \! {\cal D}\frac{\phi}{\sqrt{\hbar}}~\exp\left\{ \frac{i}{\hbar} \underbrace{\left(S[\phi]+J_k \phi^k\right)}_{=:~S_J[\phi]}\right\}\cr ~\stackrel{\begin{array}{c}\text{WKB}\cr\text{approx.}\end{array}}{\sim}& {\rm Det}\left(\frac{1}{i}\frac{\delta^2 S[\phi_{fi}[J]]}{\delta \phi^m \delta \phi^n}\right)^{-1/2}\cr &\exp\left\{ \frac{i}{\hbar}\underbrace{\left(S[\phi_{fi}[J]]+J_k \phi_{fi}^k[J]\right)}_{\text{on-shell action}}\right\}\cr &\left(1+ {\cal O}(\hbar)\right) \end{align}\tag{A}$$ in the stationary phase/WKB approximation $\hbar\to 0$. Here $\phi_{fi}^k[J]$ denotes the solution to the Dirichlet boundary value problem $$ \left\{ \begin{array}{rcl} \frac{\delta S[\phi]}{\delta \phi^k}&\approx&-J_k, \cr \phi(t_i)&=&\phi_i,\cr \phi(t_f)&=&\phi_f,\end{array}\right.\tag{B} $$ which we will assume exists and is unique$^1$. It follows from the $\hbar$/loop-expansion that the generator of connected tree diagrams $$\frac{\hbar}{i}\ln Z^{\rm tree}_{fi}[J]~=~W^{c,\rm tree}_{fi}[J]~=~S[\phi]+J_k\phi^k\tag{C}$$ is the Legendre transform of the action $S[\phi]$ between bulk sources $J_k$ and field configurations $\phi^k$ that satisfy the Dirichlet boundary conditions. In particular, $W^{c,\rm tree}_{fi}[J]$ is the on-shell action.
    For more details, see eq. (A8) in my Phys.SE answer here.
    Finally let us return to OPs question. The WKB formula (A) is tree-diagrams $Z^{\rm tree}_{fi}[J]$ [as OP suggests in eq. (3), given by the on-shell action] times a 1-loop functional determinant. So because of the presence of the 1-loop functional determinant, it is strictly speaking not just tree diagrams $Z^{\rm tree}_{fi}[J]$ .
  2. The above is closely related to (but should not be confused with) the 1PI effective/proper action $$\begin{align} \exp&\left\{\frac{i}{\hbar}\Gamma_{fi}[\phi_{\rm cl}]\right\}\cr ~=~&\exp\left\{\frac{i}{\hbar}\left(W^c_{fi}[J[\phi_{\rm cl}]]-J_k[\phi_{\rm cl}]\phi^k_{\rm cl}\right)\right\} \cr ~=~&\int_{\phi(t_i)=\phi_i}^{\phi(t_f)=\phi_f} \! {\cal D}\frac{\phi}{\sqrt{\hbar}}~\exp\left\{ \frac{i}{\hbar} \left(S[\phi]+J_k[\phi_{\rm cl}] (\phi^k-\phi^k_{\rm cl})\right)\right\}\cr ~\stackrel{\begin{array}{c}\text{WKB}\cr\text{approx.}\end{array}}{\sim}& {\rm Det}\left(\frac{1}{i}\frac{\delta^2 S[\phi_{\rm cl}[J]]}{\delta \phi^m_{\rm cl} \delta \phi^n_{\rm cl}}\right)^{-1/2}\exp\left\{ \frac{i}{\hbar}S[\phi_{\rm cl}]\right\}\left(1+ {\cal O}(\hbar)\right) \end{align}\tag{D}$$ in the stationary phase/WKB approximation $\hbar\to 0$, cf. e.g. this Phys.SE post.
$^1$ If the solution is not unique, we would have to include a sum over different solutions (=instantons).
