This post is very similar in content to this one. I'm looking for a quantum implementation of the transformations
$$ x_i \to x_i + f(p) p_i, $$
$$ p_i \to h(p) p_i. $$
In these, the subindex $i$ denotes components of $\mathbf{x}$ and $\mathbf{p}$; and $f(p)$ and $h(p)$ are scalar functions of $p\equiv|\mathbf{p}|$. So I'm looking for the operator $T$ implementing
$$ T x_i T^{-1} = x_i + f(p) p_i, $$
$$ T p_i T^{-1} = h(p) p_i. $$
I tried guessing an expression for $T$ inspired by the accepted answer to the post mentioned at the beginnig, but I couldn't work out the calculations to verify if I guessed it right. When trying to do so, I used the relation
$$ [A, e^B] = \int_0^1 ds e^{(1-s)B}[A,B]e^{sB} $$
discussed here, but got trapped in seemly never-ending nested, multiple integrals.
ADDENDUM
As pointed out in the comments, the transformations above are (classicaly) canonical only for the trivial case of $h=1$. To make my question more pertinent, I rephrase it removing the required transformation for $x_i$. Therefore, I ask for the quantum implementation of the transformation $p_i \to h(p) p_i$, letting the transformation of $x_i$ be determined after requiring canonicity.
Hint: well, to break down and modularize your problem to several technical ones, if you stuck to one dimension and dismissed QM, so you worked in the p-representation where $\hat x$ is proportional to $d/dp$, and you sought the operator T which scales p by a function thereof, $$ T p T^{-1}= p ~ h(p), $$ then, simply consider Lagrange's celebrated operator, $e^{d/dk} f(k)e^{-d/dk}= f(k+1)$ : $$ \Large T=e^{\frac{1}{k'(p)}\frac{d}{dp}} = e^{ \frac{d}{dk(p)}} ~~~\leadsto \\ TpT^{-1}= k^{-1} \Bigl ( k(p) + 1 \Bigr )= p~ h(p), ~~~\implies \\ k(p) + 1= k(p~h(p)) ~, $$ a functional equation specifying k in terms of h.
For example, confirm that $h(p)=\sqrt{1+1/p^2}~\leadsto k(p)=p^2$, so $$ e^{ \frac{d}{d(p^2)}}~ p ~e^{ -\frac{d}{d(p^2)}}=e^{ \frac{d}{d(p^2)}}~\sqrt{ p^2 }~e^{ -\frac{d}{d(p^2)}}= \sqrt{1+p^2} =p ~h(p) . $$ (This illustration does not satisfy your h(0)=1 condition, of course, but I opted for a simple and direct one for intuitiveness, rather than a messier one that would satisfy it.)
Cosmas Zachos
  • 67,623
