My coordinate transformation is:
\begin{align}
t=\frac{1}{a} e^{a \xi} \sinh (a \eta), \quad x=\frac{1}{a} e^{a \xi} \cosh (a \eta).
\end{align}
The free scalar field is quantized under this coordinate by:
\begin{align}
\phi=\sum_{k}\left(\hat{b}_{k} g_{k}+\hat{b}_{k}^{\dagger} g_{k}^{*}\right).
\end{align}
By Bogoliubov transformation, the particle number distribution in Minkowski vacuum is:
\begin{align}
\left\langle 0_{\mathrm{M}}\left|\hat{b}_{k}^{ \dagger} \hat{b}_{k}^{}\right| 0_{\mathrm{M}}\right\rangle \propto \frac{1}{e^{2 \pi \omega / a}-1}.
\end{align}
This is a thermal spectrum of bosons with temperature $T=a/2\pi$. Then many textbooks claim that it is the temperature measured by observer $\xi=0$, but I dont quite understand. As far
as I see, $\hat{b}_{k}\hat{b}_{k}^{\dagger}$ is not a local operator, thus the temperature should be the average temperature of the whole Rindler wedge. Due to the red shift, Rindler observer with larger $\xi$ should measure a lower temperature:
\begin{align}
T(\xi) = e^{-a\xi} \cdot T(\xi=0).
\end{align}
I think the average temperature should be defined as:
\begin{align}
\bar{T} = \frac{\int{T(\xi)\sqrt{\gamma}}d\xi}{\int{\sqrt{\gamma}}d\xi},
\end{align}
but it does not give the right result. However, if I define in this way:
\begin{align}
\bar{T} = \frac{\int{T(\xi)\sqrt{\gamma}}d\xi}{\int{d\xi}},
\end{align}
it really gives $\bar{T} = T(\xi=0)$. But the denominator in this definition is coordinate-dependent. Do I miss something? Or my average temperature argument is wrong?
I know that Unruh effect can also be obtained by considering the interaction of an accelerating detector with the field. There is no ambiguity in this case. But I still wish to find a physical explanation under the framework of Bogoliubov transformation.
