I tried asking this question on Worldbuilding.SE but did not get much response outside of, "you cant do that." I've also seen many similar questions without the type of answer I am looking for. So I apologize in advance if I am breaking any rules. I will do my best to stay within them.
A ring, approximately 100 meters in diameter, and 1 meter in all other dimensions. And for this experiments purposes this ring is perfectly rigid.
If you spin this ring to ever increasing velocities (10-20-30-50-90% of $c$). What effects/affects would it display or take on the local environment?
I'm certain that there would be effects manifested I am not equipped to even ask about.
  • I have imagined that it would deflect any dust or solar wind particles in spectacular fashion with mini nuclear explosions.
  • How would it appear visually?
  • If you could see the object, would it appear to be moving(rotating)? If it did would the spinward (approaching) side appear blue, and anti-spinward appear red?
  • Would it begin to emit any radiation of it's own? How much? in dangerous amounts?
  • Or would it be EM quiet if it were not acted on from the outside?
  • Gravity? Would it produce gravitational or magnetic effects in its vicinity? Would this ring shape produce any special interactions?
  • Unruh radiation, dynamical Casimir effect other exotic side effects?
I am aware that there are no perfectly ridged object, and even if there were it's still impossible. I'm also aware that the centrifugal forces would tear this structure into itty-bitty bits.
Also note: The question does not mean this object is spinning FASTER that C. Only approaching the speed of light. 30-50-90% the seed of what ever allows an answer.
