In the hydrogen atom, for $n=2$, I want to find all possible states.
For $l=0$ this is easy, and so it is with most of $l=1$. There are two states, however, that I don't understand. They are: $$\Psi_1 =|n=2;l=1;j=1/2;m_j=1/2>$$ $$\Psi_1 =|n=2;l=1;j=1/2;m_j=-1/2>$$ I find this incredibly confusing, because if $j=l+s$, then I get $1+1/2=1/2$, which doesn't make any sense. I know from the Clebsch-Gordon tables and from Griffith's book (Chapter intermediate Zeeman effect) that this state exists, but I can't wrap my head around it. I would appreciate any explanation on how to understand this state
Yes, worded this way it doesn't make sense. It seems you have misunderstood something.
When you have two angular momentum momenta (with $l$ and $s$), then these can couple to give states with several different total angular momenta ($j$):
  • The largest possible value is $j_\text{max}=l+s$,
  • the smallest possible value is $j_\text{min}=|l-s|$.
  • and also the $j$ values in between (with step size $1$) are possible.
Summarizing this you have $$j = l+s,\ l+s-1,\ l+s-2,\ ...,\ |l-s|.$$
For your example ($l=1$ and $s=\frac{1}{2}$) this boils down to just two possible values of $j$: $$j = \frac{3}{2},\ \frac{1}{2}.$$
You can visualize these two groups of states like this. When $\vec{L}$ and $\vec{S}$ are nearly parallel then you get the longest $\vec{J}$ ($j=\frac{3}{2}$). When they are nearly antiparallel then you get the shortest $\vec{J}$ ($j=\frac{1}{2}$). And for every $j$ there are $2j+1$ different states, from $m_j=+j$ (i.e. $\vec{J}$ pointing up) to $m_j=-j$ (i.e. $\vec{J}$ pointing down).
(image from Hyperphysics - Russell-Saunders or L-S coupling)
The $2$ states with $j=\frac{1}{2}$ are (taken from Angular Momentum in the Hydrogen Atom where this is worked out in detail):
$$\begin{align} \left|n=2;l=1;j=\frac{1}{2};m_j=+\frac{1}{2}\right> &=\sqrt{\frac{1}{3}}\left|n=2;l=1;m_l=0;m_s=+\frac{1}{2}\right> \\ &-\sqrt{\frac{2}{3}}\left|n=2;l=1;m_l=+1;m_s=-\frac{1}{2}\right> \\ \left|n=2;l=1;j=\frac{1}{2};m_j=-\frac{1}{2}\right> &=\sqrt{\frac{2}{3}}\left|n=2;l=1;m_l=-1;m_s=+\frac{1}{2}\right> \\ &-\sqrt{\frac{1}{3}}\left|n=2;l=1;m_l=0;m_s=-\frac{1}{2}\right> \end{align}$$
