Suppose we have a quantum mechanical particle prepared in a pure state $\psi$, and an apparatus that can measure the orbital angular momentum of the particle along a specified orthogonal axis ($x$, $y$, or $z$). First we measure its angular momentum along $x$, then along $y$, and then along $z$.
We repeat this experimental procedure for a huge number $n$ of identically prepared particles and record the results. So for each particle $k \in \{1,2,\ldots,n\}$ we have three real values we'll call $L_{x_k}$, $L_{y_k}$, and $L_{z_k}$. Finally, we make a histogram / empirical probability distribution of the squared-magnitude $L_k^2 := L_{x_k}^2 + L_{y_k}^2 + L_{z_k}^2\ \ \forall k$.
My questions are:
  1. Will the histogram of the squared-magnitude depend on the order that the angular momentum components were measured in? E.g. if we had instead first measured along $y$, then $x$, then $z$.
  2. Will the histogram of the squared-magnitude match the Born probability distribution of $\psi$ expressed on the eigenbasis of the operator $\hat{L^2}$? Or does the latter only correspond to an apparatus that can measure the squared-magnitude "directly"? (As opposed to via a deterministic function of the individual axis measurements).
  3. In general, if one has an observable $\hat{Q}$ that can be expressed as a function of other "constituent" observables $\hat{Q} = f(\hat{T}_1, \hat{T}_2, \ldots)$, does the Born distribution of $\psi$ expressed on the eigenbasis of $\hat{Q}$ match the probabilistic pushforward through $f$ of the Born distributions for the individual experiments $\{\hat{T}_1, \hat{T}_2, \ldots\}$?
I would be surprised if the answer to #3 is "yes" (with a corresponding "no" to #1 and "yes" to #2) because it allows handling quantum mechanical predictions with classical probability theory in a way that I never see done: monte carlo the Born distributions of the individual observables $\{\hat{T}_1, \hat{T}_2, \ldots\}$ and pass the results through $f$ deterministically to compute statistics for $\hat{Q}$ (as opposed to ever finding the eigenbasis of $\hat{Q}$). But I don't really know quantum mechanics "in practice" so perhaps this is done all the time?
jnez71
  • 164
tl;dr 1. Yes 2. No 3. No
During each measurement, the quantum state changes (collapses) to the observed eigenstate -- or in the case of a degenerate eigenvalue, projects onto the observed eigenspace. So your sequential measurements are operating on different states.
In the case of observables $\hat T_i$ that mutually commute, there is a common eigenbasis for all the observables, including $\hat Q$, so measuring the $\hat T_i$ sequentially just performs the collapse in stages (projections), leading to the same distribution for $Q$. It doesn't generally lead to the same state as measuring $\hat Q$ directly, though, because the latter would preserve any superposition within an eigenspace of $\hat Q$ that is collapsed by measuring the $\hat T_i$.
But the observables $\hat L_x,\hat L_y,\hat L_z$ do not commute. Measurements of each operate in different eigenbases. This is what makes quantum mechanics behave differently from classical probability. For example, if the particle starts in a state with $L^2 = 2$, then each measurement of $\hat L_x,\hat L_y,\hat L_z$ can give values $\{-1,0,1\}$. Thus, your "measurement" $L^2_k$ can be as low as $0$ or as high as $3$, whereas the actual $L^2$ is always $2$. (Indeed, the state remains in this eigenspace of $\hat L^2$ during the measurements because $\hat L_x,\hat L_y,\hat L_z$ each individually commute with $\hat L^2$.)
nanoman
  • 4,058
  • 15
