In wikipedia https://en.wikipedia.org/wiki/Canonical_commutation_relation. In quantum mechanics the Hamiltonian ${\hat {H}}$, (generalized) coordinate $ {\hat {Q}}$ and (generalized) momentum ${\hat {P}}$ are all linear operators. Further, since the Hamiltonian operator depends on the (generalized) coordinate and momentum operators, it can be viewed as a functional, and we may write (using functional derivatives): $$[{\hat {H}},{\hat {Q}}]=\frac{\delta \hat{H}}{\delta \hat{P}}\cdot[\hat{P},\hat{Q}]\tag{1}$$ $$[{\hat {H}},{\hat {P}}]=\frac{\delta \hat{H}}{\delta \hat{Q}}\cdot[\hat{Q},\hat{P}]\tag{2}$$
Why do these two equations hold?
Du Xin
  • 75
There are several issues with OP's mentioned formulas (1) & (2) on the Wikipedia page (December 2021).
  • For starters a functional derivative (well, any derivative) does not readily make sense for operators wrt. an operator. There are all kinds of operator ordering issues$^1$.
Let us therefore from now on interpret (1) & (2) classically, i.e. remove all operator hats, and replace the commutator with a Poisson bracket.
  • In the point mechanical case, the functional derivative in eqs. (1) & (2) is just an ordinary partial derivative.
  • In field theory, the canonical variables $Q^i(x)$ and $P_j(x)$ depends of a spatial coordinate $x$. The canonical Poisson bracket then becomes $$\begin{align} \{Q^i(x),P_j(y)\} ~=~& \delta^i_j \delta^d(x\!-\!y), \cr \{Q^i(x),Q^j(y)\} ~=~&0, \cr \{P_i(x),P_j(y)\} ~=~&0.\end{align} $$ The Hamiltonian $$H~=~\int_M\! d^dx ~{\cal H}(Q(x),P(x),\partial Q(x),\partial P(x),x)$$ is then a local functional integrated over $x$-space. The dot in eqs. (1) & (2) presumably stands for a DeWitt condensed notation with an implicit summation and integration over repeated discrete and continuous indices.
In both cases, eqs. (1) & (2) follows from definitions.
$^1$ A remedy is in principle to introduce symbols for the operators, and a symbol-operator ordering prescription, e.g. Weyl-ordering, Wick-ordering, etc.
The commutation with a conjugate operator does the same thing as a functional derivative. Assume that $$ [\hat{P}(x_1),\hat{Q}(x_2)] = \delta(x_2-x_1) ~~~ \text{and} ~~~ [\hat{P},\hat{P}] = [\hat{Q},\hat{Q}] = 0 . $$ Then $$ [\hat{P}^n,\hat{Q}]\cdot F = n \hat{P}^{n-1}\cdot F , $$ where $F$ is some arbitrary function of $x$. On the other hand, for $$ \frac{\delta\hat{P}(x_2)}{\delta \hat{P}(x_1)} = \delta(x_2-x_1) , $$ we have $$ \frac{\delta \hat{P}^n}{\delta \hat{P}(x_1)} \cdot F = n \hat{P}^{n-1} \cdot F . $$
Then, assuming $\hat{H}$ is a bivariate polynomial in $\hat{P}$ and $\hat{Q}$, it follows that the right-hand sides and left-hand sides in the two equations would produce the same results.
flippiefanus
  • 16,824
