The bosonic path integral computes transition amplitudes. E.g. for a scalar field $\phi$, the amplitude between state $|\phi_1\rangle$ on Cauchy surface $\Sigma_1$ and $|\phi_2\rangle$ on $\Sigma_2$ is given by \begin{equation} \langle \phi_2|U_{\Sigma_1\to\Sigma_2}|\phi_1\rangle=\int_{\phi|_{\Sigma_1}=\phi_1}^{\phi|_{\Sigma_2}=\phi_2}D\phi e^{iS[\phi]}.\tag{1} \end{equation} (I'm writing $U_{\Sigma_1\to\Sigma_2}$ for the unitary evolution between the Cauchy surfaces, and $S$ for the action).
I'd like to know whether the fermionic path integral admits a similar interpretation. More precisely, if $\psi_1, \psi_2$ are Grassman-valued fields on $\Sigma_1,\Sigma_2$ (resp.), let us define: \begin{equation} Z[\psi_1,\psi_2]\equiv \int_{\psi|_{\Sigma_1}=\psi_1}^{\psi|_{\Sigma_2}=\psi_2}D\psi D\bar{\psi}e^{iS[\psi,\bar{\psi}]},\tag{2} \end{equation} where the path integral is understood to be fermionic.
What is the meaning of $Z[\psi_1,\psi_2]$? It's not clear how it can be a transition amplitude, since $\psi_1$ and $\psi_2$ don't seem to label states in the Hilbert space in any obvious way. (Compare this with the scalar case, where $\phi_1$ and $\phi_2$ label corresponding field eigenstates). But perhaps there is some nice way to associate $\psi_1$ and $\psi_2$ with states in Hilbert space, in such a way that $Z[\psi_1,\psi_2]$ gives the amplitude between the associated states.
If there is no interpretation of $Z[\psi_1,\psi_2]$ as a transition amplitude, then my question becomes: what is the reason for introducing such path integrals at all?
OP provides no references, so the context of OP's eq. (2) is not completely clear, but let us make the following general warning about supernumbers:
  1. An observable/measurable quantity can only consist of ordinary numbers (belonging to $\mathbb{C}$). It does not make sense to measure a soul-valued output in an actual physical experiment, cf. e.g. this related Phys.SE post.
  2. The soul-part of a supernumber [and in particular a Grassmann-odd variable like $\psi_1$ and $\psi_2$ in OP's eq. (2)] is an indeterminate/a placeholder/has no value. So e.g. (the absolute square of) OP's eq. (2) has no meaning as a (relative) probability as it stands.
  3. The only way to achieve a measurable quantity from a Grassmann-odd variable is to integrate it out, cf. e.g. this related Phys.SE post.
  4. In other words, OP's fermionic construction (2) should eventually include the Berezin integrations $\int\!\mathrm{d}\psi_1\int\!\mathrm{d}\psi_2$ in order to produce a physically measurable quantity, like an overlap or a probability.
