$\newcommand\norm[1]{\lVert#1\rVert}$ $\newcommand\ket[1]{|#1\rangle}$
I consider an Hamiltonian of the Harmonic Oscillator $\hat{H} = \frac{P^2}{2m}+\frac{1}{2}m\omega^2 X^2$.
I proved already if the initial state of the Harmonic Oscillator is given by the coherent state $\ket{\psi}(t=0) = \ket{\alpha}$, then at any time $t\geq t_0=0$, the coherent state must be equal to $\ket{\psi}(t) = e^{-i\omega t/2}\ket{\alpha e^{-i\omega t}}$.
This proof uses several well-known relations. But to do it, I had to "guess" a relation: it is quite similar to a relation I have had the opportunity to prove earlier, but I have seen it nowhere. Can someone fact-check my proof?
Here it is.
\begin{align} \ket{\psi}(t) &= \sum_{n\geq 0}e^{-i\frac{\omega t}{2}}e^{-i\omega tn}\ket{\alpha}\notag\\ &= e^{-i\frac{\omega t}{2}}\sum_{n\geq 0}e^{-i\omega tn}e^{-\frac{1}{2}\norm{\alpha}^2+\alpha a^\dagger}\ket{0}\notag\\ &= e^{-i\frac{\omega t}{2}}\sum_{n\geq 0}e^{-i\omega tn}e^{-\frac{1}{2}\norm{\alpha}^2+\alpha a^\dagger}\frac{a^n}{\sqrt{n!}}\ket{n}\notag\\ &= e^{-i\frac{\omega t}{2}}\sum_{n\geq 0}e^{-\frac{1}{2}\norm{\alpha}^2+\alpha a^\dagger}\frac{\left(ae^{-i\omega t}\right)^n}{\sqrt{n!}}\ket{n}\notag\\ &= e^{-i\frac{\omega t}{2}}\sum_{n\geq 0}e^{-\frac{1}{2}\norm{\alpha}^2+\alpha a^\dagger}\ket{0e^{-i\omega t}}\notag\\ \ket{\psi}(t) &= e^{-i\frac{\omega t}{2}}\ket{\alpha e^{-i\omega t}} \end{align}
Where I introduced the relation $\ket{0} = \frac{a^n}{\sqrt{n!}}\ket{n}$, which makes intuitively sense. Is this correct?
