Consider if you had a box, inside is an apple in a vacuum not affected by any gravitational fields. The position and momentum of the apple is unknown, you can only make observations of this apple by firing another apple into the box and using an apple detector that is a claw that can catch the apple you fired in.
Does the uncertainty principle apply to the apple in this system? If so then can you conclude that the uncertainty principle can never be proven to be a property of nature as opposed to a scale problem of measurement.
