17
I'd like to estimate the colour-temperature of sunlight (as applied in photography) based on the position of the sun in the sky for a mobile phone app I'm working on (app link from a more appropriate question -Are there any mobile applications that calculate sunrise/sunset based on location?).
I'm already able to determine the position of the sun in the sky based on the date, time, latitude and longitude.
From this position (sun elevation from the horizon) I'd like to estimate the colour-temperature assuming clear skys. I understand there are factors such as how overcast the sky is that I won't be able to take into account. I'll assume an unobstructed view of the horizon.
E.g. Something like the following.
Light Source                    Colour Temperature in K
Sunrise and Sunset              2,000 to 3,000
Sunlight at 10 Degree elevation 3,500
Sunlight at 20 Degree elevation 4,000
Sunlight at 30 Degree elevation 4,500
Noon Sun and Clear Sky          4,900 to 5,800
Start of Blue Hour              ?
Is there a formula I can use that directly relates the estimated colour temperature to the suns position in the sky?
Note, this question was originally asked on the photography stack exchange but was migrated here as more of a physics based problem.
My current understanding of the problem is that I'll need to apply Rayleigh scattering and possibly Mie scattering.
The following image from Cambridge in colour shows an (exaggerated?) colour temperature scale with dawn (1), sunrise (2), midday (3), sunset (4) and dusk (5) marked. Exaggerated sky colour temperature
The sun's color is directly related to the air mass its light travels through to reach the observer.
An article which relates the air mass to the observed spectrum of the sun is linked here. In particular, equation 17 provides the intensity seen by an observer as a function of wavelength, accounting for contributions from air molecules and aerosols. This equation applies to an observer at sea level, although the role of altitude is also discussed in the article.
At a given zenith angle, one can then calculate the radiation spectrum as a function of wavelength, for various levels of aerosols (figures 9, 10, and 11).
The resulting spectra are no longer Planckian, and you'll have to apply your favorite definition of color temperature to each one.
kleingordon
  • 6,714
  • 23
  • 47
I have not seen formulae directly deriving correlated colour temperature (CCT) from solar angle, probably because there are far too many variables as mentioned in comments, plus a simple formula to convert to a CCT would be imprecise. However, it might be possible to derive your own approximation from experience or published sources, bearing in mind that spectrum for the full sky depends greatly on cloud cover and air quality; and also depends on specific directions in the sky - the clear blue sky, and the 'blue hour', probably have a CCT of infinity, while something illuminated by a setting sun might have an appropriate temperature below 5700 K. Would data from a phone's CCD and accelerometer be good enough for a future app?
For a daytime clear sky, a paper by Sekine (1989) estimates atmospheric transmittance (clarity) under different conditions, and fits temperatures to various solar elevations while looking N at 45° (which might be typical shadow under clear sky). Reading from figures 2-7, eg with the Sun at 75°, CCT is about 10 000 K...
    North ~45°  Other
90°  8 000 K
75° 10 000 K    8000 K (zenith)
60° 13 000 K
50° 15 000 K    8000 K (sunwards), 6000 K (horizon)
30° 20 000 K
This is probably because of Mie scattering when the Sun is overhead. So the paper describes possible means of calculation, but for the full sky, it gives similar approximate results for any solar elevation over 20°:
6 000 K for a hazy sky
8 000 K for a clear sky with sun
20 000 K for clear sky without sun.
However, for lower elevations and twilight, chroma changes of course. A 2003 paper by Raymond Lee has chromaticity plots for twilight with some temperatures marked, but the paths as the sun sets are wildly variable. Very roughly paraphrasing for convenience: with the sun around 5° above the horizon, the (u,v) co-ordinates are around (0.2, 0.48) maybe 6000 K; at 4° below the horizon (0.195, 0.44) and at -7° (0.175, [0.39,0.44]) 77 000 K or infinite temperature. LOWTRAN modelling gives much lower temperatures, 4250 K at 5°, (0.205, 0.47) at -3° and around 12000 K at -6°. A sunlit sheet is also cooler, reaching 6 100 K at -1°.
