Consider a sub-system in a pure state, expressed on the basis of the observable $O$, whose only eigenstates are $|a\rangle$ & $|b\rangle$. The state is $\frac{1}{\sqrt{2}}(|a\rangle+|b\rangle)$.
There is also a measuring device that measures $O$, initially separated from the sub-system. It is in state $|o\rangle$. The device might or might not include a human being, it doesn't matter.
Eventually they both interact. We can see this interaction in (at least) two ways:
  1. According to only the "deterministic-wave-dynamic" (Schrödinger's equation, or whatever equivalent): We consider the global system that contains both sub-system and measurer, which after the interaction becomes always only $\frac{1}{\sqrt{2}}(|a\rangle|Measured_A\rangle+|b\rangle|Measured_B\rangle)$. Repeating this experiment many times will then yield set of states that are all exactly the same.
  2. According to the "deterministic-wave-dynamic", and also to another additional dynamic, "probabilistic-collapse-dynamic": We consider the global system that contains both sub-system and measurer, which after the interaction becomes either $|a\rangle|Measured_A\rangle$ or $|b\rangle|Measured_B\rangle)$, with such probability given by the wave-dynamic. In this case, $50:50$. Repeating this experiment many times will then yield a statistical mixture of both different states.
Experiment shows that the final observed result is the one given by $2.$, not $1.$. If I'm not mistaken, this procedure is called "the Copenhagen interpretation". However, it is still possible to claim that 1. is correct by using "the Many Worlds interpretation". It states that the measurer is capable of interacting and thus observing only the result with which he is correlated. The $50:50$ probability observed is attributed to the idea, "if there are many worlds, what are the chances that I am in this one?"
Now, both of these are called "interpretations". This means that, despite their apparent differences, they should always predict the exact same results for all possible experiments.
But that is not true here. I can think of an experiment that differentiates them.
The global system is made to interact with another external measurer, which measures observable $X$, whose only eigenstates are:
$$|+\rangle = \frac{1}{\sqrt{2}} \left(|a\rangle|Measured_A\rangle + |b\rangle|Measured_B\rangle\right) \\ |-\rangle = \frac{1}{\sqrt{2}} \left(|a\rangle|Measured_A\rangle - |b\rangle|Measured_B\rangle \right) $$
A measurement of this observable yields |−⟩ 50% of the time for the Copenhagen interpretation, but never yields |−⟩ for the Many Worlds interpretation. Of course this experiment is unfeasible because the enormous complexity of the first measuring device. But it is possible in theory, which is enough for me to say:
They are not interpretations. They are entirely different theories. Is this correct?
Juan Perez
  • 3,082
