In an elastic collision, I understand that momentum is conserved and kinetic energy is conserved. If billiard ball of silver (with velocity $v_{(Ag)}$ impacts a stationary billiard ball of aluminum, I am trying to calculate the velocity of the aluminum ball after the collision, $v_{(Al)}$. After an elastic collision, the impactor is at rest and the impactee has the motion.
Using momentum, $= m \cdot v$
$$m_{(Ag)} \cdot v_{(Ag)} = m_{(Al)} \cdot v_{(Al)}$$
Assuming silver is 4x denser than aluminium, then using momentum, the aluminium ball should have velocity
$$v_{(Al)} = 4\cdot v_{(Ag)}$$
But if we use kinetic energy, $1/2 m \cdot v^2$
$$\frac12m_{(Ag)}\cdot v_{(ag)}^2=\frac12m_{(Al)}\cdot v_{(Al)}^2$$
$$v_{(Al)}^2=\frac{m_{(Ag)}}{m_{(Al)}}\cdot v_{(Ag)}^2$$
$$v_{(Al)}=\left(\frac{m_{(Ag)}}{m_{(Al)}}\right)^{\frac12}\cdot v_{(Ag)}$$
$$v_{(Al)}=2\cdot v_{(Ag)}$$
Somewhere I have lost some neuron connections in my brain because I cannot resolve this conflict. This is a perfectly elastic collision so both momentum and kinetic energy should be conserved.
I have read multiple threads including:
When is energy conserved in a collision and not momentum?
How to calculate velocities after collision?
How can I calculate the final velocities of two spheres after an elastic collision?
Calculating new velocities of $n$-dimensional particles after collision
Velocities in an elastic collision
Summation of the velocities before and after an elastic collision
aquagremlin
  • 1,729
If the objects have different masses, then there isn't a way to start the collision with object 1 moving and object 2 at rest and then end the collision with object 1 at rest and object 2 moving while also having the collision be elastic. You have over-constrained your system, and so you will find contradictions like the one you found here.
Using the equations from this answer in one of your linked questions, if we are setting $v_{A,f}=v_{B,i}=0$, then we end up with the system of equations $$0 = \dfrac{m_A - m_B}{m_A+m_B} v_{A,i}$$ $$v_{B,f} = \dfrac{2m_A}{m_A+m_B} v_{A,i}$$
Which you can see is only consistent if $v_{A,i}=v_{B,f}=0$ for $m_A\neq m_B$ (which is the case of no collision), or if $m_A=m_B$.
BioPhysicist
  • 59,060
If a small mass collides elastically with a larger one which was at rest, the smaller one will bounce back, not stop.
R.W. Bird
  • 12,280
You say...
That is only true if the masses of the two balls are equal. Clearly they will not be equal if one is made of silver and the other aluminium.
