-1
Studying the sum of angular momentum in quantum mechanics, tensor products were introduced to us to get the general system from the individual states. There's a property that says: $(av)\otimes w = a(v \otimes w)= v\otimes (aw) $. We will call it (1). But I don't get it's physical meaning. It's as if I scale one vector, but not the other, and the vector of the total system scales by that factor¿?.
For example, for two particles with spin $\frac{1}{2}$, I have the state $ |\frac{1}{2},m_1\rangle \otimes |\frac{1}{2},m_2\rangle $ for $m_i=\frac{1}{2},-\frac{1}{2}$. If I measure the $z$ component of the spin of the first particle ($S_1$), I get the value $\hbar m_1$, with $|\frac{1}{2},m1\rangle$ an eigenvector of that operator. Hence, we have that: $ (S_{1,z} \otimes 1) (|\frac{1}{2},m_1\rangle \otimes |\frac{1}{2},m_2\rangle)=(\hbar m_1 |\frac{1}{2},m_1\rangle) \otimes |\frac{1}{2},m_2\rangle $ and by the property (1) that's just equal to: $ \hbar m_1( |\frac{1}{2},m_1\rangle \otimes |\frac{1}{2},m_2\rangle)$. Which seems to imply that $|\frac{1}{2},m_1\rangle \otimes |\frac{1}{2},m_2\rangle$ is an eigenvector of $S_{1,z} \otimes 1$ with eigenvalue $\hbar m_1$ (the measurement of state 1 is scaling the total system by that factor). Or what's worse, by the third equality in (1), that: $ (S_{1,z} \otimes 1) (|\frac{1}{2},m_1\rangle \otimes |\frac{1}{2},m_2\rangle)= |\frac{1}{2},m_1\rangle \otimes (\hbar m_1 |\frac{1}{2},m_2\rangle) $ (that the measurement in the first state scales the second one by that factor ¿¿¿???). But that's not the case in reality. The measurement in state 1 doesn't change things that way.
I don't get what's going on, I don't understand much tensor products. If you can shed some light on this.
This is because of geometry.
Tensors actually generalise vectors to higher dimensional arrows. Whilst a vector is a single arrow, a 2-tensor, which was can also call a 2-vector, is defined by two arrows and so on.
This means, that whilst there is only one way of adding two vectors - the usual parallelogram law - there are 2 ways of adding 2-tensors and 5 ways of adding 5-tensors and so on. And these additions are just generalisations of the vector additivity law. It's quite clear if you draw out the second and third cases - the higher cases obviously can't be drawn in our 3d world.
This takes care of the additivity of tensors. Your question is about the internal scaling of tensors where $au \otimes v = u \otimes av = a(u \otimes v)$.
Again this is a geometric property, it means that we can recale a tensor whilst keeping its geometric area the same. If you draw a 2-tensor, that is a 2-vector as two arrows so that they form a parallelogram, you'll see that rescaling one side by $a$ means that you must rescale the other side by $1/a$, and hence the geometric area remains the same. I recommend drawing out the diagram as it's quite clear then.
Tensors are very geometric notions, although typically they aren't introduced in this fashion.
Mozibur Ullah
  • 14,713
