A question I came across: A soap bubble is made in vacuum by blowing an ideal diatomic gas in it. Assume the heat capacity of the soap film is much greater than that of the gas in the bubble. What will be the molar heat capacity of the gas in the bubble?
The correct answer is given as $4R$ (R being the ideal gas constant), and I was able to reach this answer using the ideal gas equation to find $dV$, substituting into the first law of thermodynamics and using the fact that $C_v$ for a diatomic gas is $5R/2$.
However, to reach this answer I had to take the pressure inside the bubble as $8\sigma/r$ ($\sigma$ being the surface tension of the soap solution) instead of $4\sigma/r$ which is what I would usually take for the excess pressure inside a soap bubble, and since it is in vacuum I can take as the absolute pressure inside the bubble.
Is there a reason for this which I'm missing, or an error in the question/answer?
