This is a follow up question to my earlier question here:
Increasing the Voltage, Ohms law, what am I missing?
A short summery of what was the problem in my original question is this:
We have a circuit with a power source and a resistor. When we increase the voltage we increase the energy to each electron(voltage is energy per charge). If we use classical mechanics and assume that the work done by the resistor is constant, then the electron would accelerate. In Dales answer he explained that as we increase the voltage we also increase the energy removed by the resistance. The force that the resistance has on the electron increases with current density. That's why we will get a new constant current, and not an increasing current. He also explained that we need QED to explain what is going on.
I am wondering if it is possible to explain this phenomenon to someone who hasn't taken quantum physics? Why does exactly the work the resistor does increase when the current increases? Can these concepts be explained (fairly) simply?
