In most books I've seen, it is explained that for inelastic collisions involving regular sized objects that the energy is lost in deforming the body and as heat(*). I want to know if this same concept apply for collisions between atomic particles? For example, say a collision between a neutron and a ionized helium atom.
Does the energy always go into excitation of the other atom?
*:This point I found discussed and applied very well in this answer for deriving kinetic energy
This is a bad example , because 1) it is not a diminution of the macroscopic case of inelastic collisions.2) neutrons are neutral and have very small probability of interaction
No, take the simple case of an electron scattering off a neutral hydrogen atom.
There will be a probability for
  1. scattering elastically in the center of mass, in the lab frame where the hydrogen is assumed at rest kinetic energy will be acqured by the atom . The probability is small since the atom is neutral
  2. Enough energy transferred to the atom for the electron to go to a higher excited state, and decay back to ground state by emitting a photon with the energy difference
  3. the electron loses enough energy for the hydrogen atom to be ionized and its electron leaves with some energy
(this answer of mine has bubble chamber pictures that illustrate part of this)
Collisions between atoms at higher energies than the ones studied classically,may transfer energy as in 2. and 3., replacing the incoming electron of the argument, with another atom. 1. is the usual scattering studied with classical statistical mechanics.
This is at the atomic level, where all interactions are due to the electromagnetic field. Scatterins of neutrons belongs to the study of strong nuclear interactions.
anna v
  • 236,935
