I am dealing with a problem of a 2 level system (an ion in my case) placed in a Penning trap. Basically the ion is moving inside the trap under the influence of the magnetic and electric field and I need to study its inner 2 level system (basically the lowest 2 energy states) while it is moving. For simplicity assume that we look only at the axial motion, so that the ion oscillates up and down. If I treat the ion motion classically, assuming it moves like $z = z_0 cos(\omega t)$ and the electric field in the z direction is (I care about the electric field in my case, as I want to mix the 2 levels of opposite parity): $E = E_0z$, the field that the ion feels in its intrinsic frame is $E=E_0z_0cos(\omega t)$. From here I just treat the 2 level system under the influence of an oscillatory electric field, which is doable. However, now I need to solve the same problem assuming the ion motion is quantized. I can't write its position as $z = z_0 cos(\omega t)$ anymore, as its position is described by a wavefunction now. But now I am not sure what does the ion see in its own reference frame. I am not sure how to move from the ion motion in the lab frame (and by this I mean the wavefunction squared distribution) to the ion frame, such that I can extract the field that the ion sees and then proceed with calculating the effect on the 2 level system. Can someone advise me about this (or point me towards any readings)? Thank you!
Asked
Active
Viewed 122 times
