From the EPR article:
"If, without in any way disturbing a system, we can predict with certainty (i.e., with probability equal to unity) the value of a physical quantity, then there exists an element of physical reality corresponding to this physical quantity."
I do not see how a local quantum theory violates this notion of realism. Would it not be more accurate to say that the option is between non-separable realism and separable non-realism?
A.D.
  • 196
Realism in this sense states that measurable things have a value, whether or not they are actually measured. This lends a sense of objective realism to the measured quantities in the sense that they don't need a subject observing them to have that value. It's trivial to build a patchwork quilt theory which gets the answer "right" for everything observed, but lacks a value for things which don't have a subject actively observing them.
The issues that arise with Bell's theorem appear when you try to define these values without creating contradictions.
Cort Ammon
  • 53,814
  • 103
  • 176
Realism means that there are hidden variables that can explain the statistical results in a deterministic way. A non realist theory has no hidden variables, and thus the value of the variable to be measured could not have a defined value until it is measured. Here the measurement result is randomly chosen (within some distribution) at the moment of the measurement.
Notice that non-realism, with its inherent randomness, should not have any advantage in being able to reproduce quantum correlations. What magical process would enable this? Without non-local information a non-real local algorithm should be as bad as a real local one in reproducing quantum correlations.
I have asked multiple times to colleagues about this issue, and also read quite a bit, and I could never find an argument about why non realism could get away with non-locality. In my opinion Bell's theorem really show that QM is non local, because local non-realism is becoming just a word to avoid saying "no-local".
PS: some give QM as an example of a local non-realist theory, but this argument is circular, because it explicitly assumes in advance that QM is local.
