Suppose two incoming photons one coming from the axis x and the other from the y axis, both in the positive direction of this axes. Now suppose we put a beam splitter in the origin, oriented with 45° wrt x axis. The initial state of the photon x is (1,0) and of the photon y is (0,1) After both meet the beam splitter, the photon x states now become (1,i) and the photon y becomes (i,1) (non normalized).
This is what i read, but i am not understand the latter part, how does this change of states occurs? I would guess that the change of phases make the photon x become (1,-1) and the y (-1,1), -1 = i*i = rotation of 180° or, in another word, change of phase of 180°
You should think link this. After the beam splitter the light rays will be in superposition of (1,0) and (0,1). It means that if you measure the polarization of photon x after the beam splitter it is 50% of the time (1,0) and 50% (0,1). If you calculate the probability of (1,i) you will find that it is 50% of the time (1,0) and 50% (0,1).
Polarization of type (1,i) i.e. when there is "i" in there, means rotating. You can think of (1,i) and (i,1) as a circular polarization which can be archived by superpositioning of (1,0) and (0,1).
Last note, a photon which comes out of an interaction is always circularly polarized i.e. it carries angular momentum. (1,0) and (0,1) polarization are always superposition of left- and right-handed photons.
Kian Maleki
  • 1,174
