The notation $C^*$ used in the title of the questions refers to a type of topological algebra unsuited for coordinate and momentum in $L^2 (\mathbb R)$. Such an algebra is made up of bounded operators, while $x$ and $p_x$ aren’t. There are, however, two possibilities to make sense of this question:
- Transform the operators $x$ and $p_x$ into bounded operators on a dense subset of $ L^2 (\mathbb R) $.
- Replace the $C^*$ algebra with an $O^*$-algebra which is perfectly possible, because such an $O^*$-algebra on $L^2 (\mathbb R)$ can be defined because the Schwartz test function space $\mathcal S (\mathbb R) $ is both invariant for the two operators and dense everywhere in $L^2 (\mathbb R)$ (the operators are essentially self-adjoint as operators from $\mathcal S (\mathbb R) $ to $L^2 (\mathbb R)$ under the $L^2 (\mathbb R)$ topology).
Possibility #1 is the start of the so-called rigged Hilbert space formulation of Quantum Mechanics, in the sense in which the norm topology of $L^2 (\mathbb R)$ on such a dense subset is replaced by a stronger topology induced by a countable family of semi-norms. If the dense subset is chosen (again) to be the Schwartz test function space, then the RHS is $\mathcal S (\mathbb R) \subset L^2 (\mathbb R) \subset \mathcal S^\times (\mathbb R) $ and the seminorms on $\mathcal S $ are (up to equivalence):
$$ ||\phi||_p = \mbox{sup}_{k,q\leq p} \left|x^k \frac{\partial^q \phi(x)}{\partial x^q}\right|, ~ p = 0,1,2,... $$
So $x$ and $p_x$ (as initially an irreducbile set) become bounded self-adjoint operators on $\mathcal S (\mathbb R) $ and from here any other operators which can be written as (properly symmetrized) polynomial functions in the two variables $x$ and $p_x$ remain bounded everywhere self-adjoint operators on $\mathcal S (\mathbb R) $. Such an operator could be the Hamiltonian of a free particle in 1D or of a harmonic oscilator in 1D or any powers of it.
Possibility #2 is clearly now equivalent to Possibility #1, because the Schwartz space and a representation of the abstract Weyl-algebra on it (such as the Schrödinger representation) provide an example of an $O^*$-algebra. This $O^*$-algebra can be enlarged by adding any (again properly symmetrized) polynomial function of $x$ and $p_x$.
So, if the question in the title is phrased: „Is there a self-adjoint operator on $L^2 (\mathbb R) $ outside of the $O^*$-algebra generated by $x$ and $p_x$?”, I would say: „No, but I would rather use $\mathcal S (\mathbb R)$ in phrasing of the question, because the full Hilbert space is too big for the $O^*$-algebra” (and ironically too small to solve the spectral equation of either of the two operators).
