14
In the Schrodinger Equation's solution for electron orbital energy levels of the hydrogen atom there is no temperature dependency. $$ E_n = - \frac{m_{\text{e}} \, e^4}{8 \, \epsilon_0^2 \, h^2 \, n^2} $$
Maybe this is due to ignoring the effects of temperature when deriving the Hamiltonian. No sources I have seen mention any assumptions about temperature. Are electron orbital energies dependent on temperature in spite of this common equation?
If you have hydrogen gas heated to near ionization then it should take less than 13.6 eV to remove an electron.
For some reason Im having trouble confirming any of this thru google. Is it 13.6 eV no matter what temperature it is or is there a temperature dependency?
Urb
  • 2,724
Jason
  • 669
5 Answers5
18
How are you defining heat at the quantum level? The Schrodinger equation describes how objects behave at the quantum level and heat describes a form energy which is transferred between objects of different temperatures. Temperature is a macroscopic quantity and not microscopic. The equation above describes the energy of electrons in a specific shell and these electrons can change energy by the absorption or emission of photons, and photons do not possess temperature.
For exactly those reasons.
No they are not.
No. Heating hydrogen will not cause the absorption of photons which is needed to ionise hydrogen (other methods for ionisation of atoms exist, but I’m speaking in the context of this question). Moreover, the hydrogen will be ionised upon the absorption of photon with this energy and not any less. This is the crux of the term energy and other quantities are quantised at a microscopic level which gave rise to quantum mechanics.
Once again temperature is not relevant here. For ionisation to occur, a photon must be absorbed (there are other ways to ionise atoms too). So to answer your question, there is no such dependence.
joseph h
  • 31,821
11
In addition to @joseph h’s answer, I would like to add that the effect of temperature on the spectra of atoms is part of what is known as as Doppler broadening of the lines.
In atomic physics, Doppler broadening is the broadening of spectral lines due to the Doppler effect caused by a distribution of velocities of atoms or molecules. Different velocities of the emitting particles result in different Doppler shifts, the cumulative effect of which is the line broadening. This resulting line profile is known as a Doppler profile. A particular case is the thermal Doppler broadening due to the thermal motion of the particles. Then, the broadening depends only on the frequency of the spectral line, the mass of the emitting particles, and their temperature, and therefore can be used for inferring the temperature of an emitting body.
Italics mine
joseph h
  • 31,821
anna v
  • 236,935
I think this question belies a misunderstanding of the nature of temperature.
Temperature is not an input to fundamental physical laws, it is something that comes out of the physical laws when applied to a large number of objects. There is no explicit temperature in the Schrödinger equation for a hydrogen atom. The concept of temperature only emerges when you consider the Schrödinger equation for a large number of hydrogen atoms that can exchange energy with each other.
The Schrödinger equation (or Newton's laws or Maxwell's equations) establish the ground rules for how atoms and molecules (or any other objects) behave. However, it's usually difficult to work out what these rules predict for anything more than simple systems. The point of statistical mechanics is to predict the average behavior of a large number of such simple systems under the constraints provided by the ground rules (fundamental physical laws). Temperature is a concept that emerges from the statistics of large number of degrees of freedom that can exchange energy. Again, it is not an input to the Schrödinger equation or Newton's laws, but a consequence of them!
Temperature is a macroscopic property. Individual atoms don't have temperature. An analogy would be income inequality: it makes sense to ask how much income inequality a country or state or city has, but it doesn't make sense to ask how much income inequality a single person has. A simplified version of what temperature is is that it is a measure of how much difference between velocities there is between atoms. Just as it doesn't make sense to ask how much difference between incomes there is when you're talking about a single person, it doesn't make sense to ask how much difference in velocities there is if you're talking about a single atom.
If anything, heating a gas will increase the ionization energy. The ionization energy is given for the frame of reference of the atom. If an atom is moving at a high speed relative to us, then the ionization energy in our frame energy is increased.
It's not clear what you mean by "heated to near ionization". According to this, 13.6 eV corresponds to 158 thousand degrees Kelvin. So if you were to heat hydrogen to that temperature, you would see ionization from the collisions. But that doesn't mean the ionization energy is decreased, it means the energy is met.
Temperaturile foarte inalte peste 1000 de grade pot ioniza atomii fapt binecunoscut de la tuburile electronice, dar nu pot modifica dimensiunile atomilor sau a ionilor respectivi. Anumite radiatii de frecventa inalta produc salturi ale electronilor de pe o orbita pe alta dar acest lucru nu inseamna ca se modifica dimensiunile atomilor, ci doar starea energetica momentana a acestora.
