I was following along Mark Thomson's Modern Particle Physics, and got stuck on this book's derivation of Fermi's Golden Rule (On page 53):
"... If there are d$n$ accessible final states in the energy range $E_f \rightarrow E_f +dE_f$, then the total transition rate $\Gamma_{fi}$ is given by \begin{equation} \Gamma_{fi} = 2\pi \int|T_{fi}|^2 \frac{dn}{dE_f} \lim_{T\rightarrow \infty} \left\{ \frac{1}{T} \int_{-\frac{T}{2}}^{-\frac{T}{2}} e^{i(E_f - E_i)t} \delta(E_f-E_i) dt \right\}dE_f \tag{A}. \end{equation} The delta-function in the integral implies that $E_f=E_i$ and therefore $(\text{A})$ can be written \begin{equation} \Gamma_{fi} = 2\pi \int|T_{fi}|^2 \frac{dn}{dE_f} \delta(E_f-E_i) \lim_{T\rightarrow \infty} \left\{ \frac{1}{T} \int_{-\frac{T}{2}}^{-\frac{T}{2}} dt \right\}dE_f \tag{B}. \end{equation} ... (and so on) "
Based on the explanation between the steps, I don't understand why $E_f$ and $E_i$ should be the same. I do know that in order for $E_f$ to be the same as $E_i$, the Dirac-delta functions supposed to be integrated with the exponent, but this is not the case. Any explanation for this would be appreciated.
This is just an application of the rule \begin{align} \int dx\;f(x)g(x) \delta(x-y) = f(y)g(y) &= f(y)\int dx\; g(x)\delta(x-y)\\ &= \int dx\; f(y)g(x) \delta(x-y) \end{align} where we have used the definition of the delta function. Intuitively the Dirac delta is zero except where its argument vanishes, so the value $f$ only matters at that point, so we can make the substitution and get the same answer.
Here $f$ is the seemingly complicated function $$ f(E_f) = \lim_{T\rightarrow\infty}\frac{1}{T}\int_{-T/2}^{T/2} dt \;e^{\imath (E_f-E_i) t} $$ and $$ g(E_f) = |T_{if}|^2 \frac{d n}{dE_f} $$
By Symmetry
  • 9,649
I think this can be quickly resolved with a reference to the wikipedia page on the dirac delta:
Approach 1) as T goes to infinity, the integral becomes delta of the energy difference, so there may be a square of dirac deltas which is the same as a dirac delta. However, I'm not sure why the division by T can be absorbed in the dirac delta... As commented below, this is physically unreasonable.
Approach 2): The answer is easier than possibility 1 - the definition of the Dirac delta means that the argument, here $E_i-E_f$, is zero. This is used to set the argument of the exponential to zero.
Approach 2 seems to be what was used here. Reviewing the wikipedia page on the Dirac delta might help you get a handle on why it is this way.
PrawwarP
  • 477
