The Peierls substitution is given by the following formula: $$t_{12}\rightarrow t'_{12}=\exp\left[\int_{{\bf R}_{1}}^{{\bf R}_{2}}{\bf A}({\bf r})\cdot d{\bf r}\right]t_{12}.$$
What are the meanings of the ${\bf R}_{1}$ and and ${\bf R}_{2}$? For example, let us assume that I have a NaCl crystal with body center cubic structure. The fractional coordinates are $(0, 0, 0)$ for Na and $(\frac{1}{2}, \frac{1}{2}, \frac{1}{2})$ for Cl, and the lattice vectors are $({\bf a},{\bf b},{\bf c})$. Now, the $t_{12}$ is defined as the hopping from the $p$ orbital of Cl [in the cell ${\bf R}(lmn)=l{\bf a}+m{\bf b}+n{\bf c}$] to the $s$ orbital of Na [in the cell of ${\bf R}(uvw)=u{\bf a}+v{\bf b}+w{\bf c}$]. Now my question is: If we want to do Peierls substitution, should I use ${\bf R}_{1}=l{\bf a}+m{\bf b}+n{\bf c}+\frac{1}{2}{\bf a}+\frac{1}{2}{\bf b}+\frac{1}{2}{\bf c}$ and ${\bf R}_{2}=u{\bf a}+v{\bf b}+w{\bf c}$, or should I use ${\bf R}_{1}=l{\bf a}+m{\bf b}+n{\bf c}$ and ${\bf R}_{2}=u{\bf a}+v{\bf b}+w{\bf c}$?
Solidstate
  • 57
Don't know if this is still relevant to you after all the years. But I think $R1=la+mb+nc+1/2a+1/2b+1/2c$ and $R2=ua+vb+wc$ is the way to go. Because we should make sure that the accumulated phase due to the presence of $\vec{A}$ can reproduce flux $\phi$ through any loop. Thus only by using $R_1$ and $R_2$ as their actual positions can you ensure that the total phase $\Pi_{i \in \text{loop}}exp(\int_{R_i}^{R_{i+1}} \vec{A} \cdot d\vec{r})$ along the loop is accumulated to $\phi = \oint \vec{A} \cdot d\vec{r}$
Also, this can be checked out carefully following the derivation of Peierls substitution on Wiki: https://en.wikipedia.org/wiki/Peierls_substitution#Another_derivation
zyt_329
  • 53
