I am wondering what is an average intermolecular distance in liquid water (say under normal pressure and room temperature).
I need just order of magnitude. A reference would be helpful.
MKO
  • 2,349
One mole of liquid water has a mass of 18 grams (two hydrogen atoms with mass 1, one oxygen with 16), occupies 18cm³ and contains roughly 6e23 molecules.
So, the average single molecule occupies 3e-23cm³. If you assume that to be a cube (good enough for the order of magnitude), you get a dimension of 3.1e-8cm, or 0.31 nanometer.
And that's the average distance between the water molecules.
In liquids the molecules are packed densely. Therefore the intermolecular distance is about equal to the size of the molecules (which for water is around $3 \cdot 10^{-10}$ m).
