If E=hf is applicable for electron and other particles, the De Broglie wavelength should be λ=hv/pc. Because, mc^2=hf which implies mc^2=hc/λ which implies m=h/λc and thus λ=hv/pc. But I have found in my text book that λ=h/p is applicable not only for photon but also for all particle. But how can λ=h/p=h/mv be applicable for all particle?
The De Broglie relations $$ E=h\nu, p=\frac{h}{\lambda} $$ are applicable to all particles. However the relation between the frequency/energy and the wave length/momentum, is not the same. Thus, for photons $f=\frac{c}{\lambda}$, for non-relativistic electrons $E=\frac{p^2}{2m}$, for relativistic electrons $E^2=m^2c^4 + p^2c^2$.
Roger V.
  • 68,984
For your last step you just introduce a v in both the numerator and denominator. That is meaningless as it is unity.
In the expression $\lambda = \frac{h}{mc}$, you just have to set $c=v$ to account for particles with different momenta and thus different velocities, not equal to the speed of light.
Do it in this way:
$$E = hf = mc^2 $$ $$\frac{hc}{\lambda} = mc^2$$ $$\frac{h}{\lambda} = mc$$ $$\lambda = \frac{h}{mc}$$ $$\lambda = \frac{h}{mv}$$
