I have this paragraph in a book:
The vectors $T,U$ and $V=T\times U$ define a moving frame along the path $X$. Let $\Omega$ denote the angular velocity vector describing the rate of rotation of the frame with respect to arclength $s$ so, that $T'=\Omega\times T$, $U'=\Omega\times U$ and $V'=\Omega\times V$. Let $\omega_1,\omega_2,\omega_3$ be the components of $\Omega$ referred to the moving frame, i.e. $\Omega=\omega_1T+\omega_2U+\omega_3V$. Then $\omega_1$ represents the angular rate at which $U$ revolves about $X$.
I understand from wikipedia that the angular velocity vector for a frame is the angular velocity for each vector that composes the frame, but I don't understand how they calculate the angular velocity for each one.
What I understood was that the angular velocity vector of $r$ is $\frac{r\times r'}{|r|^2}$, where the dividend is the cross product of the vector $r$ with its derivative, and the divisor is the square of the norm of $r$. But then why if I will calculate the angular velocity of each vector $\Omega$ is a $3$-dimensional vector if I will get three vectors of dimension $3$?
P.S. I will be really thankful if your explanation is as clear as possible, since I'm learning this by myself.
EDIT:
To make it clear, I don't get how is obtained in a basic way the angular velocity of a frame and I want to understand (if it's possible with an example) how is obtained for a given frame (and if it's related, for only a vector too). What I don't understand from wikipedia is the section of Particle in three dimensions and the part of Spin angular from a frame, because the paragraph I mention states about ONE vector but what I understand from the wikipedia article is that I must calculate THREE vectors, so I need an explanation.
iam_agf
  • 101
The formula $${\boldsymbol \omega}\stackrel{?}{=} \frac{{\bf r}\times \dot {\bf r}}{|{\bf r}|^2} $$ is only true if the angular velocity ${\boldsymbol \omega}$ is pependicular to ${\bf r}$. There was another question involving this wrong expression recently. Where did you find this misleading formula?
The correct definition of the angular velocity about some point O is $$ \dot {\bf r}= {\boldsymbol \omega}\times {\bf r}, $$ where ${\bf r}$ is the position vector measured from O.
Note added: I found the misleading formula in the Wikipedia article on angular velocity. This article contains the horribly wrong equation $$ {\boldsymbol \omega}\stackrel{?}{=} \frac{{\bf r}\times \dot {\bf r}}{|{\bf r}|^2}= {\bf e}_1\times \dot {\bf e}_1= {\bf e}_2\times \dot {\bf e}_2= {\bf e}_1\times \dot {\bf e}_2 $$ In which the last three equalities cannot possibly be true because they imply that ${\boldsymbol \omega}$ is perpendicular to all of ${\bf e}_1, {\bf e}_2,{\bf e}_3$, and so must be zero!
mike stone
  • 58,971
  • 53
  • 158
