I just studied Heisenberg's uncertainty principle in school and I came up with an interesting problem.
Assume an electron which is moving very slowly and we observe it with a distance uncertainty of say $\Delta x=1\times10^{-13} \text{ m}$ if we try finding uncertainty of velocity using the formula $$\Delta x \cdot \Delta v\ge \dfrac{h}{4\pi m}$$
$$\Delta v=578838179.9 \text{ m/s}$$
Which is clearly greater than the speed of light but that is not possible. How did physicists overcome this challenge?
- 2,517
- 22
- 25
- 41
- 595
The right formula is $$\Delta X \Delta P \geq h/4\pi$$ where $P$ is the momentum which is approximatively $mv$ only for small velocities $v$ when compared with $c$. Otherwise you have to use the relativistic expression $$P = mv/ \sqrt{1-v^2/c^2}.$$ If $\Delta X$ is small, then $\Delta P$ is large but, according to the formula above, the speed remains of the order of $c$ at most. That is because, in the formula above, $P\to +\infty$ corresponds to $v\to c$.
With some details, solving the above identity for $v$, we have $$v = \frac{P}{m \sqrt{1+ P^2/m^2c^2}}\:,$$ so that $$v\pm \Delta v = \frac{P\pm \Delta P}{m \sqrt{1+ (P\pm \Delta P)^2/m^2c^2}}.$$ We have obtained the exact expression of $\Delta v$: $$\pm \Delta v = \frac{P\pm \Delta P}{m \sqrt{1+ (P\pm \Delta P)^2/m^2c^2}} - \frac{P}{m \sqrt{1+ P^2/m^2c^2}},$$ where $$\Delta P = \frac{\hbar}{2\Delta X}\:.$$ This is a complicated expression but it is easy to see that the final speed cannot exceed $c$ in any cases. For a fixed value of $P$ and $\Delta X \to 0$, we have $$v\pm \Delta v = \lim_{\Delta P \to + \infty}\frac{P\pm \Delta P}{m \sqrt{1+ (P \pm \Delta P)^2/m^2c^2}}= \pm c\:.\tag{1}$$
Finally, it is not difficult to see that (using the graph of the hyperbolic tangent function) $$-1 \leq \frac{(P\pm \Delta P)/mc}{ \sqrt{1+ (P \pm \Delta P)^2/m^2c^2}}\leq 1\tag{2}\:.$$ We therefore conclude that $$-c \leq v\pm \Delta v \leq c,$$ where the boundary values are achieved only for $\Delta X \to 0$ according to (1). Relativity is safe...
- 80,330
What you've discovered is that "normal" Quantum Mechanics is incompatible with relativity. As Valter Moretti pointed out, using a relativistic expression for momentum solves this problem. There are, however, more problems that cannot be solved by simply using relativistic expression for energy and momentum. For example,
- The relativistic equation $E=mc^2$ implies that it is possible for energy to be converted into new particles. The time-energy uncertainty principle $\left(\Delta E\cdot\Delta t\geq\hbar/2\right)$ implies that it is possible for particles to be created out of thin air, even when, from a classical viewpoint, there is not enough energy present.
- Even when single-particle quantum mechanics is modified to use a relativistic Hamiltonian, as in the Klein-Gordon equation, there is always a non-zero probability that a particle can teleport across a space-like interval (faster than the speed of light).
These problems are resolved by the introduction of Quantum Field Theory. Basically, instead of quantizing individual particles, we quantize fields. The particles are excitations of the fields, and new particles can appear out of thin air. Quantum field theories are designed to preserve causality so that they work well with relativity. The mathematics is all very complicated, but that's the basic idea.
- 4,211
There are two problems with this setup. The first is here:
If you know already that the electron is moving very slowly then you already have a small uncertainty in momentum. For example, if you know that the electron is moving at less than $1 \text{ m/s}$ then $\Delta v = 0.29 \text{ m/s}$ so we already have $\Delta p = 2.6 \ 10^{-31}\text{ kg m/s}$. By $\Delta x \ \Delta p \ge \hbar/2$ then $\Delta x \ge 0.0002\text{ m}$ so the distance uncertainty mentioned in the setup is not possible.
Of course, perhaps you meant something different by "moving very slowly", but if you work through the numbers then $\Delta x = 10^{-13}\text{ m}$ gives an uncertainty of velocity $\Delta v \ge 0.88 \ c$ which would be hard to justify as "very slowly" regardless.
EDIT: Per the comment below "very slowly" refers to a non-relativistic velocity. If we insist on $\gamma < 1.01$ then that corresponds to $v < 4.2 \ 10^7 \text{ m/s}$. This is $\Delta v < 1.2 \ 10^7 \text{ m/s}$ or a maximum of $\Delta p = 1.1 \ 10^{-23} \text{ kg m/s}$. So by Heisenberg's uncertainty principle the minimum uncertainty in position is $\Delta x > \hbar/(2\Delta p) = 4.8 \ 10^{-12}\text{ m}$
The second problem is
using the formula $$\Delta x. \Delta v\ge \frac{h}{4\pi m}$$
The correct expression is $\Delta p \Delta x\ge \hbar/2$. This is important because $p=mv$ is only a non-relativistic approximation. In relativity $p=mv/\sqrt{1-v^2/c^2}$ which is unbounded as $v$ approaches $c$. With this correct formula $\Delta x = 10^{-13}\text{ m}$ results in $\Delta p = 5.3 \ 10^{-22} \text{ kg m/s}$. As indicated above, for an electron this corresponds to a velocity uncertainty of $\Delta v = 0.88 \ c$ which is quite large, but does not exceed $c$.
- 117,350
So when you become a particle (or nuclear) physicist , one of the first things you need to memorize is that:
$$ \hbar c \approx 200\,{\rm MeV\cdot fm}$$
where "fm" is a fermi ($10^{-15}\,$m), which is the scale of a nucleon.
Thus, if your position uncertainty is 100 fm, you can immediately estimate a momentum uncertainty of 1 MeV/c.
Since you've also memorized $m_e=0.511\,$MeV/c$^2$, that means the velocity uncertainty (which isn't really a thing in particle physics, it never comes up) corresponds to a Lorentz factor of:
$$\gamma = \frac{E}{m_e} \approx \frac p {m_e} \approx 2,$$
and we've all done enough relativity problem to know this corresponds to a velocity:
$$ \beta = \frac v c = \frac{\sqrt 3} 2 \approx 0.866$$
which is close enough to @Dale's answer.
- 42,131
Assume an electron which is moving very slowly and we observe it with a distance uncertainty of say Δx=1×10−13 m
In QM, particles don't have velocities in the normal sense of the word. Velocity is an observable, and thus is represented by an operator applied to a quantum state. Talking of a particle's "velocity" implies that the particle has a definite velocity (i.e. is in an eigenstate of the velocity operator) or, at the very least, its state has a small spread in velocity space. As you calculated, an electron with such a small $\Delta x$ would have such a massive $\Delta p$ that it cannot be said to have anything close to a well-defined velocity.
If an electron is moving close to $c$, then it will traverse $10^{-13}m$ in ~$3*10^{-22}$ seconds. According to a cursory web search that I performed, the highest time precision ever recorded is $10^{-21}s$. https://www.smithsonianmag.com/smart-news/physicists-record-smallest-slice-time-yet-180961085/ So it's not possible to measure an electron over short enough time period for it to be confined within a region of $10^{-13}m$.
That is not to say that it is not legitimate to ask about a purely hypothetical, completely unmeasurable scenario in which over a period of less than a zeptosecond, an electron has $\Delta x = 10^{-13}m$. I just thought it should be pointed out that this is a physically unrealistic situation.
As for this apparently resutling in $\Delta v > c$, as Valter Moretti says, your calculation is based on $p = mv$, and if $m$ is taken to be the rest mass $m_0$, then this is valid only for small $v$ (relative to $c$). However, I don't think Valter Moretti's further calculations are valid. The $\Delta p$ in the uncertainty is not the range of $p$, although this interpretation is a good enough approximation to be a good intuition when the priciple is being introduced. Rather, $\Delta p$ is the standard deviation of $p$: $\sqrt {<\phi^* |p \phi>^2-<\phi^* |p^2 \phi>}$. Since $p$ is a nonlinear function of $v$, we can't calculate an exact value of $\Delta v$ in terms of $\Delta p$ without knowing the exact $\phi$.
- 13,541
- 9,687
