37
When reading the term superselection sector, I always wrongly thought this must have something to do with supersymmetry ... DON'T laugh at me ... ;-)
But now I have read in this answer, that for example for a free QFT highly excited states , that would need infinite occupation numbers to build them up, and that lie therefore outside the Fock space are said to lie in a (different?) superselection sector. If a state has finite or infinite energy depends on the Hamiltonian, and a finite energy and physically relevant Hilbert space can be obtainend from the inacessible infinite energy states of another Hamiltonian.
This makes me now want to really know what a superselection sector is. What are the key ideas behind the definition of a superselection sector? Are they an underlaying concept to derive quantum field theories with a physical hilbert space that has only finite energy states, or what is their common use in physics?
Dilaton
  • 9,771
A superposition sector is a subspace of the Hilbert space ${\mathcal H}_i$ such that the total Hilbert space of the physical system may be described as the direct sum $$ {\mathcal H} = {\mathcal H}_1 \oplus {\mathcal H}_2 \oplus\cdots \oplus {\mathcal H}_N$$ where $N$ may be finite or infinite such that if the state vector belongs to one of these superselection sectors $$|\psi(t)\rangle\in{\mathcal H}_I,$$ then this property will hold for all times $t$: it is impossible to change the superselection sectors by any local operations or excitations.
An example in the initial comments involved the decomposition of the Hilbert space to superselection sectors ${\mathcal H}_Q$ corresponding to states with different electric charges $Q$. They don't talk to each other. A state with $Q=-7e$ may evolve to states with $Q=-7e$ only. In general, these conservation laws must be generalized to a broader concept, "superselection rules". Each superselection rule may decompose the Hilbert space into finer sectors.
It doesn't mean that one can't write down complex superpositions of states from different sectors. Indeed, the superposition postulate of quantum mechanics guarantees that they're allowed states. In practice, we don't encounter them because the measurement of total $Q$ – the identification of the precise superselection sectors – is something we can always do as parts of our analysis of a system. It means that in practice, we know this information and we may consider $|\psi\rangle$ to be an element of one particular superselection sector. It will stay in the same sector forever.
In quantum field theory and string theory, the term "superselection sector" has still the same general meaning but it is usually used for different parts of the Hilbert space of the theory – that describes the whole spacetime – which can't be reached from each other because one would need an infinite energy to do so, an infinite work to "rebuild" the spacetime. Typically, different superselection sectors are defined by different conditions of spacetime fields at infinity, in the asymptotic region.
For example, the vacuum that looks like $AdS_5\times S^5$ ground state of type IIB string theory is a state in the string theory's Hilbert space. One may add local excitations to it, gravitons, dilatons ;-), and so on, but that will keep us in the same superselection sector. The flat vacuum $M^{11}$ of M-theory is a state in string theory's Hilbert space, too. There are processes and dualities that relate the vacua, and so on. However, it is not possible to rebuild the spacetime of the $AdS$ type to the spacetime of the $M^{11}$ time by any local excitations. So if you live in one of the worlds, you may assume that you will never live in the other.
Different asymptotic values of the dilaton ;-) or any other scalar field (moduli...) or any other field that is meaningful to be given a vev define different superselection sectors. This notion applies to quantum field theories and string theory, too. In particular, when we discuss string theory and its landscape, each element of the landscape (a minimum of the potential in the complicated landscape) defines a background, a vacuum, and the whole (small) Hilbert space including this vacuum state and all the local, finite-energy excitations is a superselection sector of string theory. So using the notorious example, the F-theory flux vacua contain $10^{500}$ superselection sectors of string theory.
In the case of quantum field theory, we usually have a definition of the theory that applies to all superselection sectors. A special feature of string theory is that some of its definitions are only good for one superselection sector or a subset of superselection sectors. This is the statement that is sometimes misleadingly formulated by saying that "string theory isn't background-independent". Physics of string theory is demonstrably background-independent, there is only one string theory and the different backgrounds (and therefore the associated superselection sectors – the empty background with all allowed local, finite-energy excitations upon it) are clearly solutions to the same equations of the whole string theory. We just don't have a definition that would make this feature of string theory manifest and it is not known whether it exists.
Luboš Motl
  • 182,599
