11
It is customary in gravitational lensing problems, to project both the background source and the deflecting mass (e.g. a background quasar, and a foreground galaxy acting as a lens) in a plane.
Then, the lensing problem can be regarded as a mapping between the unlensed source plane, and the lensed image plane. In such transformations, the Jacobian evaluated at a point of the source plane, expresses how an infinitesimal area located around that point increases.
Lens mass and mass distribution, relative positions and distances involved give rise to different scenarios. The special case in which the distortions are too small to be resolved by telescopes, is called microlensing regime. Typically, a dark, unseen object like a floating planet, happens to cross transversally in front of a background star.
The image of the background star suffers amplification and distortions that are unresolved, but a change in brightness is detected, with a very typical light curve shape. The measured light curve of a microlensing event can be related to physical parameters of the problem, because the change in brightness of a lensed image can be modelled simply by dividing the area of the lensed image by that of the unlensed source image. If that can be done, it is because the mean surface flux of the image equals that of the source.
That is, gravitational lensing can make a tiny source appear bigger in the sky but in plain terms, every square inch of the image has the same brightness of every square inch of the source. Here comes my question, because that seems to me rather counter-intuitive and, when I try to find a rigorous justification to it, I find the same arcane sentence in each book, in each review, in each paper I have seen:
'Because of Liouville's theorem, gravitational lensing conserves surface brightness'
(... and therefore the magnification is found by dividing the subtended area of the image by that of the source). Every single author I have read, drops that sentence as if it were something very obvious, and quickly goes into other questions.
I have tried to trace-back the origin of the idea, by consulting the bibliography of every book or document in which that thing is stated. Interestingly, I have recognized sort of a fingerprint of obscure points like this one, a patter that is repeated in many of the documents, as if some authors didn't understand and merely copied from each other, developing and personalizing only the parts they understand in between.
I have rigorously developed and resolved every one of the dark points in that pattern, but this one remains unresolved. Is it perhaps something obvious? How is Liouville's theorem applied to photons along null geodesics? I will accept an appropiate link or paper reference as a good answer.
This question is pretty old but I figured other people than OP might be interested in the answer. I had the exact same question, so I asked my advisor and he told me that the answer can be found in two places. First (and unsurprisingly), there's a full derivation in Misner, Thorne and Wheeler, particularly on sections 22.5 and 22.6. There's also an attempt at a more intuitive explanation in Schutz's Gravity from the Ground Up, a very interesting book which attempts to explain GR with only high school math. I'm not actually sure if the explanation given there makes sense, but it has helped me arrive at one that does.
If I had to summarize the whole thing, I'd say that the conservation of surface brightness (or specific intensity, or étendue, or...) is the result of an exchange between position space volume and momentum space volume, or between solid angle and area.
I won't reproduce all the math because it can be found in MTW, but the basic idea is as follows. The first important fact is that you can think of light propagation as a bunch of "classical" photons moving along null geodesics, and the number of photons is conserved.
This photon picture allows you to use kinetic theory, as developed in section 22.6 of MTW, where Liouville's theorem is derived: given a bunch of $N$ particles, the volume $\mathcal{V}$ in phase space occupied by them, given by the product $\mathcal{V} = \mathcal{V}_x \mathcal{V}_p$ of the volume in 3-space and in momentum space as measured by a locally inertial observer, is Lorentz invariant and constant along the world line. Therefore, the number density $\mathcal{N} = N/\mathcal{V}$ is constant as well. I won't go through the proof since it is much easier to just look at the pictures in MTW, but this is the key step which has all the counterintuitive consequences.
The last step is relating the number density to the specific intensity or surface brightness $I_\nu$, the amount of energy per unit time, area of detector, frequency, and solid angle of the photons' momenta. This is a pretty standard derivation, and it makes sense. The result is that $\mathcal{N} = h^{-4} I_\nu/\nu^3$.
The frequency can change in crazy ways along the geodesic, but as long as there's no cosmological redshift between the source and the observer the net change will be zero, so for our purposes $I_\nu$ is constant, which is the result we needed. A given piece of solid angle from the observer's perspective receives the same flux no matter if there's a lens in the way or not.
As you've noticed, this has fairly counterintuitive consequences. From conservation of energy you would (wrongly) expect a bigger image to be dimmer, because a given solid angle of observation covers less of the lensed image than of the unlensed image. But the image also appears closer, so it's also brighter. Or, to put it in more careful terms, given a point on the source, light from a larger solid angle will reach the observer than if there were no lens (hope this sentence makes sense!). Conservation of phase space volume guarantees that these two effects exactly cancel each other out.
If anyone is interested in thinking through this, I have some advice. You must be careful when drawing 2D pictures, because using solid angles is essential: it can happen that images get compressed in one direction and stretched in the other, so in a 2D diagram the image would look smaller while it's actually larger. Also, you have to consider light rays emanating in a given solid angle from a point on the source as well as light rays emanating from an area on the source which converge on a point at the observer with some solid angle. This is the tradeoff between solid angle and area I mentioned earlier.
Javier
  • 28,811
What they're referring to is a property of light from geometrical optics. The conserved property is "entendue" (see wikipedia article), and the constancy of brightness can be demonstrated in a bunch of ways (Hamiltonian optics i.e. Liouville's theorem, second law of thermodynamics as above, etc.).
Nanite
  • 3,530
This is just the second law of thermodynamics.
Suppose you have some big source black body and some little target black body. You build a whole bunch of geometric optics to focus light from the source to the target (e.g. mirrors behind the target and lenses in front of it). Eventually an observer standing on the target looks up and sees light from the source at every point in the sky.
All this incoming light heats the target blackbody up until it's radiating light away as fast as it's coming in. That means the target comes up to the same temperature as the source. If you could increase the flux per unit solid angle, the target would get hotter than the source, breaking the second law.
Is this enough, or did you want a technical analysis of the lensing equation?
