While I perfectly know the true demonstration of Heisenberg uncertainty principle (from the full QM machinery), I'm looking for a very cheap heuristic way of getting $$\Delta x \, \Delta p \ge h, \tag{1}$$ without getting into the semi-classical "Heisenberg microscope" experiment, or any wave packet superposition. I need this for a very short and simple exposition to the subject for my very low level students.
I was thinking about using only the deBroglie relations (which my students are learning): $$p = \frac{h}{\lambda}, \tag{2}$$ $$E = h f, \tag{3}$$ and saying something like this: The particle's position at time $t$ is $x(t) = x_0 + v_0 t$. During a small amount of time $\Delta t$, its position cannot be measured with a better accuracy than $\Delta x = v_0 \Delta t$ (or maybe it should be $\Delta x = \Delta v_0 \, t$, or even $\Delta x \approx \lambda$ ?), thus ... after few lines of blabla and maths ... we get (1).
Any idea or suggestion on how I could get (1) by using (2) and (3), and a few basic classical kinematics formulas? Basic differential calculus is an option.
My goal is to show that the deBroglie relations (as a starting point) in one dimension only (ie on the $x$ axis) and some basic classical kinematics imply the Heisenberg uncertainty principle.
Maybe a way is to use the wave's frequency as a clock of resolution $\Delta t = 1/f$. I'll use $E = p^2 / 2m$. The particle's position cannot have a resolution better than $$\Delta x \ge v \, \Delta t = \frac{p \, \Delta t}{m} = \frac{h \, p}{m E} = \frac{2 h}{p}. \tag{4}$$ Then what? How to define the momentum's uncertainty with that clock? $$\Delta x \Delta p \ge \frac{h \, 2p \, \Delta p}{p^2} \approx h \, \frac{\Delta (p^2)}{p^2}.\tag{5}$$
