-3
This question is related to this Time between two observer in special relativity
Suppose we have to observers, $A$ and $B$ so that when they are a distance $d=c\tau$ from each other measured by observer $A$,they agree to set both their clock to zero that is, $t_A=t_B=0$ for distance=$d$. Now suppose that they are approaching, that is they both see each other with a speed $|v|$. Since $A$ sees $B$ moving his clock is faster than the clock of $B$. On the other hand $B$ sees $A$ moving so his clock is faster than the clock of $A$.
My question is when they meet each other ,how their time will be related should we have $t'_A>t'_B$,$t'_A<t'_B$ or $t'_A=t'_B$?
Neither will see the other observer's time as the same as the other observer does. When they reach points $d$ apart, as far as $A$ is concerned $t_A=0$ but $B$ at $t_B$ is still outside their light cone and they will see $B$ at an earlier time, say $t^A_B$, and vice versa. As they approach the time discrepancy $\Delta t = t_A - t^A_B$ reduces until, when they meet, $\Delta t = t_A - t^A_B = t_B - t^B_A = t_A = t_B = 0$
Guy Inchbald
  • 7,578
I really am not an expert in the field, but I remember struggling on this for a while. "Since A sees B moving his clock is faster than the clock of B" is actually misleading.I believe the correct interpretation is that the readings of the ticks of clock A that A makes in his frame are faster compared to the tick readings of clock A made by B in his frame B. The same assertion can be made by interverting the points of view, and this is true whatever the relative positions of A and B, so there is no contradiction. It just means that the time perception of the same events (ticks of a given clock) are not the same in the two frames with a relative velocity.
The only difference between this and other questions to which it is related is that you have the observers approaching and say
but this is a meaningless assigment. The twins have a different notion of when this is precisely because they define different reference frames. Therefore you should see the answers to the linked questions.
-1
These confusion arise because we separate spacetime in space +time. We should think that spacetime is a four dimensional manifold
In Special relativity spacetime is the tuple $(\mathcal{R}^4, \mathcal{O}, \mathcal{A}^{\uparrow}, \nabla, \eta, T,)$, where $\nabla$ is a torsion free connection $\eta=(+---)$ a Lorentzian metric,$\mathcal{O}$ the standard topology,$\mathcal{A}^{\uparrow}$ an atlas and $T$ a time-orientation.
A $\textbf{clock}$ carried by a specific observer $(\gamma, e)$ will measure a $\textbf{time}$ $$ time := \int_{\tau_0}^{\tau_1} d\tau \sqrt{ \eta_{\lambda(\tau)}(v_{\lambda,\lambda(\tau)}, v_{\lambda,\lambda(\tau)}) } \tag1$$ between the two $''\underline{events}''$ $$ \lambda(\tau_0) \quad \quad \quad \, \text{ "start the clock'' } $$ and $$ \lambda(\tau_1) \quad \quad \quad \, \text{ "stop the clock'' } $$ Here $v_{\lambda,\lambda(\tau)})$ is the tangent vector of the the curve $\lambda$ at the point $\lambda(\tau)$
Lets choose coordinates $(x_0=ct,x_1=x,x_2=y,x_3=z)$ such that the trajectory of observer $A$ in spacetime is given by $$\lambda_A(\tau)=(c\tau,0,0,0)$$ and the trajectory of observer $B$ in spacetime is given by $$\lambda_B=(c\tau,d-v\tau,0,0)$$From these equation we see that $A$ and $B$ meet at $\tau= \frac{d}{v}$
In these coordinates the metric is given by $$\eta=dt\otimes dt-dx\otimes dx-dy\otimes dy-dz\otimes dz \tag 2$$
and the tangents vectors are given by
$$v^A_{\lambda,\lambda(\tau)}=c \frac{\partial}{\partial t} \tag 3$$
$$v^B_{\lambda,\lambda(\tau)}=c \frac{\partial}{\partial t}-v\frac{\partial}{\partial t} \tag 4$$
so we have $$n(v^A_{\lambda,\lambda(\tau)},v^A_{\lambda,\lambda(\tau)})=c^2 \tag2$$ $$n(v^B_{\lambda,\lambda(\tau)},v^B_{\lambda,\lambda(\tau)})=c^2-v^2 \tag3$$ than the time elapsed until their meeting for observer $A$ is $$t_A=\frac{1}{c}\int_0^\frac{d}{v}\sqrt{c^2}=\frac{d}{v}$$
The time for $B$ is given by $$t_B=\frac{1}{c}\int_0^\frac{d}{v}\sqrt{c^2-v^2}=\frac{1}{\gamma}\frac{d}{v}$$
Eq.1 is coordinate independent so if we make the calculation from the perspective of $B$ we should obtain the same result.
