14
A recent paper, titled Inertia from an Asymmetric Casimir Effect, discusses the universal horizons relative to an accelerating observer (Rindler space). A figure it used to demonstrate its point challenged a view I held.
Figure 1
I previously asked a question about Rindler space, Do apparent event horizons have Hawking radiation?. My take-away from the (very good) answers was that an the Rindler Horizon (in the above figure) emits Hawking radiation in the same way that a black hole or the cosmic horizon does. This is called Unruh radiation.
This leads me to the obvious question: Does the accelerating observer see the new Unruh radiation and the old cosmic horizon's radiation?
As you accelerate to the right, then you replace the cosmic horizon to you left with a new horizon, closer to you. Radiation thus appears out of nowhere, but does that mean that the existing radiation from the prior horizon disappears?
EDITED, new material follows:
In my first version of this question I referenced both the CMB and cosmic horizon radiation. These are two different things, but I treated them as the same thing. The question was answered for the CMB - it remains just as the light from any galaxy would.
I've reformulated this so it can be about the Rindler Horizon's radiation versus radiation from the original cosmic horizon. To illustrate this, I made my own version of Figure 1 above, with more detail for the old versus new horizon. Here:
  • Cosmic horizon - horizon according to an inertial observer
  • Cosmic horizon prime - horizon according to an accelerating observer with same position and velocity as the inertial one
My Figure 1
This corresponds to Figure 1, since his surface labeled "COSMIC HORIZON" is the rightmost part of the horizon that remains the same for the accelerating observer as well as the inertial observer. His "RINDLER HORIZON" on the left is only the new horizon, leaving out the old horizon, which I have included.
If we say that $O$ just started accelerating, then what do we expect? Logical possibilities include:
  • Sees Hawking radiation from both horizons
  • Sees Hawking radiation from old horizon, which transforms into the characteristic of the new horizon over time
  • Instantly sees Hawking radiation from new horizon
I'm also not sure if I've drawn the new horizon correctly. I would think that you couldn't "reveal" any galaxy beyond the cosmic horizon at the rightmost point, but to $O$, its dark-energy acceleration is less than to the inertial observer. Maybe I should have just moved the horizon to the right instead of shrinking it? I'm not sure, but I think the paper assumed no change in the cosmic horizon Hawking radiation from the right.
Alan Rominger
  • 21,318
Thank you for your interesting question. The following is what I assumed in the paper. If you accelerate to the right, the Rindler horizon to your left is a boundary beyond which things are in principle unobservable for you. So, as soon as the nearer Rindler horizon forms, the far cosmic horizon behind it becomes unobservable and therefore (following the attitude of Mach) irrelevant. I assumed that the distance to the cosmic horizon on the right remains the same. I hope this answers your questions. It probably raises a lot of new ones!
I've just tried to reply to lurscher's question on the bullet cluster and found I can't because I need a 50 reputation. So, I'll add my answer here. My comments on the bullet cluster:
  1. It's not right to defend a general hypothesis using one example. Other clusters like the Musket ball and Abell 520 are different: there the gravitational lensing separates from the galaxies, making the whole dark matter hypothesis seem ad hoc: it has to be differently applied in different cases. http://phys.org/news/2012-03-dark-core-defies-explanation.html Why the focus then on the bullet cluster?
  2. The bullet cluster is what lawyers would call circumstantial evidence since it requires rather a lot of inference. You have to model the collision process and make assumptions.
  3. As Milgrom says, see the link below, to suggest a change in dynamical laws does not necessarily mean you have to give up all dark matter. There is probably some normal matter still not seen, just much less than proposed by dark matter, and of the normal kind (baryonic) so why not propose new dynamics rather than new particles? https://www.astro.umd.edu/~ssm/mond/moti_bullet.html
  4. The bullet cluster may be explainable by MiHsC, but I would need to have information about the motion of the matter within it, and this is not available.
  5. A cleaner test case would use globular clusters, which show the same anomalous spin as galaxies (Scarpa et al., 2006) but are too small to contain dark matter, as normally applied, and are embedded in too high an external gravity field to be explained by MoND, but can potentially be explained by MiHsC which is dependent on local accelerations. http://physicsfromtheedge.blogspot.co.uk/2012/06/scarpa-et-al.html
I think you are confusing the CMB with radiation from the apparent horizon. CMB is just relic light from the surface of last-scattering - it behaves like any light which is emitted from a source. It is totally unrelated to the Hawking radiation emitted from the horizon. A neat coincidence (as afar as we know) is that the surface of last scattering is "close" to the horizon. This just means that the age of the universe is well-approximated by the Hubble time $\sim H^{-1}$.
So in the distant future, the CMB light will redshift to absolute zero, and the dominant source of radiation will indeed be Hawking radiation from the apparent horizon.
I know this doesn't fully answer your question, but I hope it helps.
hwlin
  • 2,608
I'm happy to see that Mike himself has replied to the question (being him the author of the paper in question, and the inertia-as-a-cosmological-casimir-cutoff effect idea), but i wanted to underline a few items.
A derivation of a MOND-like acceleration cutoff for inertia as proposed by quantised inertia using heuristic by physically sound arguments, which is undoubtedly on the same order of magnitude that the one that you need for explaining galactic rotation curves, is something that requires anyone studying dark matter to stop and think about this. Is this really an explanation that can explain all that has been observed?
Indeed, this leaves a big dilemma: if you don't need dark matter to explain galactic rotation curves, what does the bullet cluster is saying? we still require dark matter to explain it? i don't think there is a clear insight as to what make of this. This, in part, what is making difficult to people studying dark matter to reconcile MiHsC with the rest of cosmological observations. After all, dark matter was proposed to solve the galactic rotation curves. And then, we found out about the bullet cluster, and how the lensing regions delineate a region that is not seemingly bound by gas collisions in the same way that observable matter. So, if we found a simple derivation that can reproduce the galactic rotation curves, in what standing does that leave the cluster observations?
This is a deep mystery
lurscher
  • 14,933
