The idea is to prove that (A) implies that the Kraus operators $A_a$ of $\mathcal E$ are local, that is, they have the form $A_a=\tilde A_a\otimes I$. For the purpose, I will leverage here the representation of the channel in terms of an enlarged unitary, and use it to prove the result on the Kraus operators.
Enlarged unitary representation
Every map CPTP $\mathcal E$ can be written as $\newcommand{\ketbra}[1]{|#1\rangle\!\langle #1|}\newcommand{\calU}{{\mathcal{U}}}\newcommand{\calE}{{\mathcal{E}}}\newcommand{\calH}{{\mathcal{H}}}\newcommand{\tr}{\operatorname{tr}}\calE(\rho)=\tr_E[\calU(\rho\otimes\ketbra{0_E}) \calU^\dagger]$ for some (unique) unitary $\calU$.
Explicitly, denoting with $K(\calE)$ the natural representation of $\calE$, the relation between $\calE$ and $\calU$ can be written as
$$K(\calE)_{ij}^{k\ell} = \sum_a \calU_{ia}^{k0} (\calU^*)_{ja}^{\ell0}.$$
Feel free to completely ignore the placement of up/down indices, I only do it to make the formula a bit easier to read.
If this looks similar to the Kraus decomposition of the channel, that's not a coincidence. The relation between the unitary $\calU$ and the Kraus operators $A_a$ is $(A_a)_i^k = \calU_{ia}^{k0}$.
While the above notation is for maps acting on a single system, the formulae translate seamlessly to a bipartite scenario by "duplicating" each index: $i\to(i_1,i_2)$, $j\to (j_1,j_2)$ etc.
What (A) implies for $\mathcal U$
Note that if (A) holds for all states $\rho_{AB}$, it holds in particular for all pure product states $|\psi\rangle|\phi\rangle$. On these states, $\calU$ must act in such a way that tracing out the subsystem $A$ still gives a pure state on $B$ (because $\tr_A(\ketbra\psi\otimes\ketbra\phi)=\ketbra\phi$ is pure). We must thus have
\calU\, |\psi\rangle_A|\phi\rangle_B|0\rangle_E = |\Psi_{AE}\rangle\otimes|\phi\rangle_B,
where $|\Psi_{AE}\rangle$ is some state in $\calH_A\otimes\calH_E$ (the joint space of $A$ and the auxiliary space $E$).
More explicitly, this expression reads
\calU_{ima}^{kn0} \psi_{k}\phi_n = \Psi_{ia} \phi_m.
If we choose $|\psi\rangle,|\phi\rangle$ to be elements of the computational basis, we conclude that
$\calU_{ima}^{kn0} = \delta_{nm} \Psi^k_{ia}$, where $\sum_{ia}\Psi^k_{ia}|i,a\rangle$ is some pure state in $\calH_A\otimes\calH_E$ for each $k$. Now all that remains is to see why this implies the original statement about the form of $\calE$.
Conclude that $\mathcal E$ is local
We proved that the Kraus operators of $\calE$ have the form
$$(A_a)_{im}^{kn} = \delta_{mn} \Psi^{k}_{ia} \Longleftrightarrow
A_a = \tilde A_a\otimes I$$
for some set of operators $\tilde A_a$ acting on $\calH_A$.
This is enough to prove the statement: a map is local if and only if its Kraus operators are. If we want to be more explicit, we can write the expressions componentwise as:
\calE(\rho) =
\sum_a A_a \rho A_a^\dagger
\Longleftrightarrow (\calE(\rho))_{im,jn} = (A_a)_{im}^{k\ell} (A_a^*)_{jn}^{pq} \rho_{k\ell,pq}
= \Psi^k_{ia}(\Psi^*)^p_{ja}\rho_{km,pn}.
We can then define the operator $\mathcal T$ with components
$$(\mathcal T)_{ij}^{kp} = \sum_a \Psi^k_{ia}(\Psi^*)^p_{ja},$$
and observe that $\calE = \mathcal T\otimes I$.
TL;DR: Consider the action of the map on pure product states, and observe that (A) implies that its Kraus operators are local.
