Well, I was wondering about the real age of our universe, I found that it's estimated to be $13.8\times 10^9$ years.
Is it an approximation, or laws behind this age?
As I said there's a mathematical laws behind this approximation.
We use the Friedmann equations and EFE : $$\begin{cases} 3\frac{\dot{a}^2}{a^2}+3\frac{kc^2}{a^2}-\Lambda c^2=\frac{8\pi G}{c^2}\rho \qquad(1) \\[2ex] -2\frac{\ddot{a}}{a}-\frac{\dot{a}^2}{a^2}-\frac{kc^2}{a^2}+\Lambda c^2=\frac{8\pi G}{c^2}p \qquad(2)\\[2ex] R_{ij}-\frac{1}{2}Rg_{ij}=\frac{8\pi G}{c^4} T_{ij} \qquad(3) \end{cases}$$ If we toke $k=0; \Lambda\neq 0$ than our universe is flat and its expansion is accelerated; thus the EFE can be written : $$R_{ij}-\frac{1}{2}Rg_{ij}-\Lambda g_{ij}=\frac{8\pi G}{c^4}T_{ij}$$ Or it can be also written : $$R_{ij}-\frac{1}{2}Rg_{ij}=\frac{8\pi G}{c^4}T_{ij}+\Lambda g_{ij} \Leftrightarrow R_{ij}-\frac{1}{2}Rg_{ij}=\frac{8\pi G}{c^4}\Bigr(T_{ij} \frac{c^4\Lambda }{8\pi G}g_{ij}\Bigl)$$ We express the stress-energy tensor for vacuum : $$T_{ij}^{\mathbf{Vacuum}}=\frac{c^4\Lambda g_{ij}}{8\pi G}$$ Comparing it with perfect fluid: $$T_{ij}^{\mathbf{Matter}}=-p.g_{ij}+\Bigl(\frac{p}{c^2}+\rho_0\Bigr)u_i u_j$$ We can simulate vacuum as a fluid $$\begin{cases} \mathbf{Pressure}\ :\ p=-\frac{\Lambda c^4}{8\pi G} \\ \mathbf{Energy\ density}\:\ \rho=-p=\frac{\Lambda c^4}{8\pi G} \end{cases}$$ Adding cosmological parameters: $$\begin{cases} \Omega_v+\Omega_m=1 \\ 2q-1+3\Omega_v =0 \end{cases} \iff \begin{cases} \Omega_m =1-\Omega_v \\ \Omega_v =\frac{1-2q}{3} \end{cases}$$ Let $t=t_0$ and $\Lambda = \frac{3\Omega_{v_0}H_0^2}{c^2}$
$$\begin{cases} \Omega_{v_0}+\frac{8\pi G \rho_0}{3c^2 H_0^2}=1 \\[2ex] \Omega_{v_0}=\frac{\Lambda c^2}{3H_0^2}=\frac{1-2q_0}{3} \end{cases} \iff \begin{cases} 1-\Omega_{v_0}=\frac{8\pi G \rho_0}{3c^2 H_0^2} \iff (1-\Omega_{v_0})\frac{H_0^2}{c^2}=\frac{8\pi G \rho_0}{3c^2} \\[2ex] \Omega_{v_0}=\frac{1-2q_0}{3} \iff 1-\Omega_{v_0}=\frac{2}{3} (1+q_0) \end{cases}$$
Thus we obtain : $$\frac{8\pi G\rho_0}{3c^4}=\frac{2}{3} \frac{H_0^2}{c^2} (1+q_0)$$ In the first equation, we are having the following :
Recall $\ k=0, \Lambda \neq 0\ $: $$3\frac{\dot{a}^2}{a^2} -\Lambda c^2=\frac{8 \pi G}{c^2}\rho$$ We know that : $\rho a^3=\rho_0 a_0^3$; thus : $\rho=\frac{\rho_0 a_0^3}{a^3} $ $$\Rightarrow 3\frac{\dot{a}^2}{a^2} -\Lambda c^2=\frac{8 \pi G}{c^2}\frac{\rho_0 a_0^3}{a^3} \iff \dot{a}^2=\frac{8 \pi G}{3c^2}\frac{\rho_0 a_0^3}{a}+\frac{\Lambda c^2 a^2}{3} \iff da=\sqrt{\underbrace{\frac{8 \pi G\rho_0 a_0^3}{3c^2}}_{K}\frac{1}{a}+\underbrace{\frac{\Lambda c^2 }{3}}_{B}a^2} dt$$ Let $ \ K=\frac{8 \pi G\rho_0 a_0^3}{3c^2}\ $ and $\ B=\frac{\Lambda c^2}{3}\ $ : $$da=\sqrt{\frac{K}{a}} \sqrt{1+\frac{B}{K} a^3} dt \iff dt=\frac{da.a^{1/2}}{\sqrt{K}\sqrt{1+\frac{B}{K} a^3}}$$ Integrating, we get the following : $$\int dt=\int \frac{da.a^{1/2}}{\sqrt{K}\sqrt{1+{\frac{B}{K} a^3}}}$$ Let $x^2=\frac{B}{K} a^3\ $ thus : $$\begin{cases} 3a^2da=2\frac{K}{B} x dx \\ a^2=\bigl(\frac{K}{B}\bigr)^{2/3} x^{4/3} \\ a^{1/2}=\bigl(\frac{K}{B}\bigr)^{1/6}x^{1/3} \end{cases}$$ So (I'm going to skip math here !) : $$\int \frac{\frac{2}{3} \bigr(\frac{K}{B}\bigl)^{1/2}dx}{\sqrt{K}\sqrt{1+\underbrace{\frac{B}{K}a^3}_{x^2}}}=\int dt \iff \frac{2}{3B^{1/2}} \text{arcsh}(x)=t \qquad(\text{I'm Skiping math !}) $$ $$\fbox{$a^3=\frac{8\pi G \rho_0 a_0^3}{c^4\Lambda}\text{sh}^2\Bigr(\frac{c}{2}\sqrt{3\Lambda}t\Bigl)$} $$ Recall : $\Lambda = \frac{3\Omega_{v_0}H_0^2}{c^2}$ and $\frac{8\pi G\rho_0}{3c^4}=\frac{2}{3} \frac{H_0^2}{c^2} (1+q_0)$
$$\require{cancel} a^3=\frac{2H_0^2(1+q_0)a_0^3}{c^2\Lambda }\text{sh}^2\Bigr(\frac{c}{2}\sqrt{3\Lambda}t\Bigl) \iff a^3=\frac{2\cancel{H_0^2}(1+q_0)a_0^3 \cancel{c^2}}{3\cancel{c^2}\Omega_{v_0}\cancel{H_0^2}}\text{sh}^2\Biggr(\frac{\cancel{c}}{2}\sqrt{\frac{9\Omega_{v_0}H_0^2}{\cancel{c^2}}}t\Biggl)$$ Therefore: $$ a^3=\frac{2a_0^3(1+q_0)}{3\Omega_{v_0}}\text{sh}^2 \Bigr(\frac{3H_0}{2}\sqrt{\Omega_{v_0}}t\Bigl)$$ and now, let us calculate this $t$, well we are going to assume that $t=t_0$ and $a=a_0$: $$\begin{aligned}\require{cancel}\cancel{a_0^3}=\frac{2\cancel{a_0^3}(1+q_0)}{3\Omega_{v_0}}\text{sh}^2 \Bigr(\frac{3H_0}{2}\sqrt{\Omega_{v_0}}t_0\Bigl) \iff \frac{3\Omega_{v_0}}{2(1+q_0)}=\text{sh}^2 \Bigr(\frac{3H_0}{2}\sqrt{\Omega_{v_0}}t_0\Bigl)\\ \iff \frac{3H_0}{2}\sqrt{\Omega_{v_0}}t_0=\text{arcsh}\Biggr(\sqrt{\frac{3\Omega_{v_0}}{2(1+q_0)}}\Biggl) \\ \iff t_0=\frac{2}{3} \frac{1}{H_0\sqrt{\Omega_{v_0}}}\text{arcsh}\Biggr(\sqrt{\frac{3\Omega_{v_0}}{2(1+q_0)}}\Biggl) \end{aligned}$$ And here you go, the formula of our universe's age : $$\fbox{$t_0=\frac{2}{3} \frac{1}{H_0\sqrt{\Omega_{v_0}}}\text{arcsh}\Biggr(\sqrt{\frac{3\Omega_{v_0}}{2(1+q_0)}}\Biggl)$}$$ The numerical substitution : $$\begin{cases} H_0^{-1}\approx 14.56\times 10^9 \\ q_0\approx -0.5245 \\ \Omega_{v_0}\approx 0.683 \end{cases}$$ Thus : $$t_0=\frac{2}{3}\times 14.56\times 10^9 \frac{1}{\sqrt{0.683}}\text{arcsh}\Biggr(\sqrt{\frac{3\times 0.683}{2(1-0.5245)}}\Biggl)\approx 13.8\times 10^9\text{y}$$ I hope now that you understood my comment, it depends on the numerical values of the cosmological parameters.
And yeah one more thing, Sorry I skipped a lot of steps in the proof because of my laziness and it is long.
I hope you have understand that there is a laws behind this approximation and this is a way to compute our universe's age. Good luck !
Of course it is approximation, as any almost any measurement beyond simple counting involves approximation, but there is quite a bit of evidence based on observation fitted to known laws.
The main evidence springs from fitting observations of cosmological parameters, Hubble's constant $H_0$, density $\Omega$, curvature $\Omega_k$, and dark energy $\Omega_\Lambda$ to Friedmann models. This is done both from supernova data and from analysis of the cosmic microwave background, with broad, but not perfect agreement (recent measurements seem to suggest a small level of disagreement, but not enough that anyone is seriously concerned).
There is also supporting evidence, as it is possible to measure the age of some of the oldest stars from their constitution.
