I came across a YouTube Video by minutephysics, a YouTuber with a Ph.D. degree in physics. In this video, he explains that the solar system is approximately flat because of two reasons:
1) conservation of angular momentum,
2) our universe has three spatial dimensions and the same does not hold in a universe with four spatial dimensions.
I completely agree with the first point, and I think it would be nice to add that under the constraints of conservation of momentum and angular momentum, the total energy is minimized if all particles lie in the same plane. I have doubts about the second point, which the video barely explains anything.
In summary, I have two questions that I need help with.
1) If we can visualize angular momentum in 3D as a vector, how should we think about its counterpart in 4D, a tensor? And what about the law of conservation of angular momentum.
2) What is the shape of the solar system in a universe with four spatial dimensions?
Charlie
  • 7,159
hb12ah
  • 113
In general, angular momentum is a geometric object called a rank $2$ differential form. To oversimplify a bit, you can think of it as a plane, along with a signed magnitude. In three dimensions, and only in three dimensions, every plane corresponds to a vector (i.e. the normal vector), so we can also think of angular momentum as a vector.
Since angular momentum is a plane in any number of dimensions, the conservation law argument actually works the exact same way: if the initial total angular momentum lies in a plane, then the solar system ends up orbiting in that plane.
At least, it would, but gravitational orbits in four spatial dimensions are not stable, or more precisely they are neutrally stable, with particles easily drifting into drastically larger or smaller orbits. For this reason, it's unclear if anything like a solar system could form at all.
knzhou
  • 107,105
