Yes I have seen the explanation of why this is so in quantum mechanical textbooks. However, let's use the identity operator and do the following:
$$\langle x|x'\rangle =\langle x|I|x'\rangle =\int\langle x|x''\rangle\langle x''|x\rangle dx''=\int\delta(x-x'')*\delta(x''-x)dx'\tag{1}$$
(the integral is from $-\infty$ to $+\infty$. Now, let's look at what we have inside the integral. Clearly, the term inside
$$\delta(x-x'')*\delta(x''-x)\tag{2}$$
is nonzero only if $x''=x'=x$. We can restate this as follows:
$$\delta(x-x'')*\delta(x''-x)=0\text{, if } x\neq x'\tag{3}$$
and
$$\delta(x'-x'')*\delta(x''-x)=\infty \text{ (for certain $x''$ in the region from $-\infty$ to $+\infty$)}\tag{4}$$
if $x=x'$; this means that
$$\delta(x-x'')*\delta(x''-x)=\delta(x'-x).\tag{5}$$
However, if we put $\delta(x'-x)$ instead of $\delta(x-x'')*\delta(x''-x)$ we get the following:
$$\int\delta(x-x'')*\delta(x''-x)dx''=\int\delta(x'-x)dx''=\delta(x'-x)\int dx''\tag{6}$$
(I remind that the integral is from $-\infty$ to $+\infty$). So I get that
$$\langle x|x'\rangle=\delta(x'-x)\int dx''\tag{7}$$
which is not just $\delta(x'-x)$. I would be grateful if someone could tell me where my assumptions are wrong and why.
Performing the manipulation you suggest, $$\langle x|x'\rangle=\langle x|\mathbb 1 |x'\rangle = \langle x|\left(\int dx'' |x'' \rangle\langle x''|\right)|x'\rangle $$ $$= \int dx '' \langle x|x''\rangle \langle x''|x'\rangle = \int dx'' \delta(x-x'')\delta(x''-x')$$
The defining property of the delta function is that $\int dx'' f(x'') \delta (x''-x') = f(x')$. Comparing that to what we have above, we get $$ \langle x|x'\rangle = \int dx'' \underbrace{\delta(x-x'')}_{\text{This is our }f(x'')} \delta(x'' - x') =\delta(x-x')$$ as expected.
You have to be careful with delta functions, because they are not proper functions, and you can get yourself into a lot of trouble by naively pretending that they are. As a general rule, delta functions are defined by how they behave inside an integral. Your mistake was when you said
$\delta(x-x'')\delta(x''-x)=0$ if $x\neq x'$ and $\delta(x'-x'')\delta(x''-x)=\infty$ (for certain $x''$ in the region from $-\infty$ to $\infty$) if $x=x'$; this means that $\delta(x-x'') \delta(x''-x) = \delta(x'-x)$.
You are using reasoning that would be applicable if the delta function were actually a function (i.e. comparing function values for various different values of the inputs) but that does not work here. You must stick to the formal defining property
$$\int dx f(x) \delta (x-a) = f(a)$$
Albatross
  • 72,909
I would say that thinking of the delta function as a function that takes value $0$ at certain points and ''$\infty$'' when the argument is $0$ can be a bit tricky. My advise is that you blindly us the definition of a delta function namely that $$\int \delta(x-y)f(y) dy = f(x)$$ and do not try to reason to it. So if you want to show that $$ \int \delta(x-x'')\delta(x''-x') dx''$$ is just $\delta(x'-x)$ just use the definition. Because what a delta function really ''is'' is just the properties of it defined by its definition.
By the way. I think your mistake is the equality $$\int \delta(x-x'')\delta(x''-x')dx'' = \int \delta(x'-x) dx''$$. If you think about this in with the definition you will see why. It should be equal to $\delta(x-x')$.
