11
Let $M$ be the magnetic moment of a system. Below are the Bloch equations, including the relaxation terms.
$$\frac{\partial M_x}{\partial t}=({\bf M} \times \gamma {\bf H_0})_x-\frac{M_x}{T_2} $$ $$ \frac{\partial M_y}{\partial t}=({\bf M} \times \gamma {\bf H_0})_y-\frac{M_y}{T_2} $$ $$\frac{\partial M_z}{\partial t}=({\bf M} \times \gamma {\bf H_0})_z+\frac{(M_{\infty}-M_z)}{T_1} $$
At $t=0$, $ {\bf M}=(0,0,M_{\infty})$.
Also, ${\bf H_0}=H_0 {\bf k'}$ where primed coordinates are in the lab frame.
Now suppose an on resonance pulse is applied along the i direction of the rotating frame for $ T_{\frac{\pi}{2}} =0.005$ milliseconds, then it is turned off to watch the free induction decay. $T_2=5$ milliseconds, $T_1=5000$ milliseconds.
So, naturally we will have nutation due to the pulse, $T_2$ decay of the transverse magnetization, and $T_1$ recovery of the longitudinal magnetization. Due to the timescales, they will proceed sequentially.
I'm trying to sketch the time evolution of the above three components of the magnetic moment in both the rotating frame and lab frame, and understand exactly how these processes are related.
Emilio Pisanty
  • 137,480
Rich
  • 111
I performed this as an undergrad experiment. We let our spins settle to achive maximum polarisation in an external magnetic field. Then a very short sine pulse ($\pi/2$) was sent into the probe to rotate the magnetisation from the $z$-Axis into the $x$-$y$-plane. The pulse looks like this:
http://chaos.stw-bonn.de/users/mu/uploads/2014-06-14/1-Puls.png
This decayed with “free induction decay” (FID) like so:
http://chaos.stw-bonn.de/users/mu/uploads/2014-06-14/2-FID.png
The $T_1$ was measured by doing a $\pi/2$ and another $\pi/2$ pulse a little later:
http://chaos.stw-bonn.de/users/mu/uploads/2014-06-14/3-T1.png
The effective $T_2$ is just measured from the FID signal:
http://chaos.stw-bonn.de/users/mu/uploads/2014-06-14/4-T2.png
And finally we ran the Meiboom-Gill-Sequence:
http://chaos.stw-bonn.de/users/mu/uploads/2014-06-14/5-MG.png
The simulator that @Tarek will let you create similar plots like the ones that we measured.
