I'm confused why the quantum state of a photon is typically regarded as its momentum (which presumably is described by 4 numbers---wavelength, direction, and angular momentum) and not by its position (which seems to be described by 3 numbers).
I understand that position and momentum are complementary measurements, so as one is known more accurately, the other is known less accurately.
So perhaps this question should read, "what is the full quantum wave equation for a photon" ? Does this question even make sense? Or does it only make sense to describe photons as a transfer of energy from one atom to another atom?
vy32
  • 536
If a photon has a well-defined momentum and energy, then it has an ill-defined position and time. A wave $e^{ik\cdot x}$ with one particular four-momentum, $\hbar k$, is a plane wave extending throughout all of spacetime.
You can consider a photon that has a well-defined position at a well-defined time, but then it doesn’t have well-defined momentum or energy.
You can’t have it both ways. This is the essence of the uncertainty principle, and one way to understood it is using basic Fourier analysis of wave packets. The spread in space, and the spread in wavelength, are inversely related.
G. Smith
  • 52,489
