-2
I'm wondering if it's possible to give a concise description that's understandable and is not as long as a book. I don't want to waste time reading the book "Principles of quantum mechanics" because I might still not understand it. I had a lot of trouble understanding the "Differential equations" textbook so I might have trouble understanding that book as well. I also had trouble understanding the Wikipedia article Schrödinger equation.
According to the Wikiquote article, Shut up and calculate, there is a standard on how to make calculations in quantum mechanics and how to interpret them. I believe one quantum theory that includes nuclear chemistry but not gravity has a standard on how to perform calculations and how to interpret some of them as a classical macroscopic event. I believe that that standard for making calculations can be simplified to another standard that gives rise to an entirely different simplified quantum mechanical theory that doesn't talk about nuclear chemistry at all that can explain hybridization of orbitals and wave functions and is relativistic. My question is
Is the last sentence true? If so, would it be possible for you to give me a really long slow understandable description that leads to an explanation of how to make calculations and how to interpret them as a classical macroscopic event and why they're interpreted that way that can be as long as you want as long as it's not longer than the typical length of a book. If it's not possible, then could you instead tell me whether it is easy to start learning somewhere and get to the point after which that book can will clearly explain quantum mechanics in an understandable way? According to this answer, it might not always be possible just from books. If the last sentence before this question is not true, what is the correction to the sentence I stated?
I don't see why we couldn't get some of the Stack Exchange users to each rarely and occasionally devote so much more time than usual to one question with different users picking different questions to devote a huge amount of time to. If that's possible, then maybe somebody will devote so much time to this question that they can give a satisfactory answer. I was interested in quantum mechanics for a long time. If as I start reading the answer, I can see that I'm able to understand what I'm reading, I probably will gradually keep reading more and more of it. At the moment, I have only one question that I want such a long answer for so I probably would eventually read the whole answer even if it's really long as long as I feel like I'm able to understand it as soon as I start reading it and don't get lost as I continue reading struggling to figure out what the answer is saying.
ZeroTheHero
  • 49,168
  • 71
  • 148
Timothy
  • 1,708
Believe what you may, the sentence
is unlikely to be true
  1. if you think that reading a standard textbook is a waste of time,
  2. given the range of phenomenon explained by the theory exposed in the standard textbooks.
There are some elementary texts explaining (slowly but not so concisely) how quantum mechanics work (see this one for instance) and if you can't get past that then suggesting you can replace the standard theory with a theory of your own is something done at your own risk.
ZeroTheHero
  • 49,168
  • 71
  • 148
