At the introduction to quantum mechanics, phase $v_p$ and group $v_g$ velocities are often presented. I know how to derive $v_p$ and get the equation:
$$ \scriptsize v_p=\frac{\omega}{k}. $$
What I don't know is how to explain a derivation of a group velocity $v_g$ to myself. Our professor did derive it, but I am having some difficulties with it.
First, he did a superposition of 2 waves with the same amplitude $s_0$:
$$ \scriptsize \begin{split} s &= s_0 \sin(\omega_1t-k_1x) + s_0 \sin(\omega_2t - k_2 x)\\ s &= s_0 \left[ \sin(\omega_1t-k_1x) + \sin(\omega_2t - k_2 x) \right]\\ s &= 2s_0 \left[ \sin\left(\frac{(\omega_1t-k_1x)+(\omega_2 t -k_2 x)}{2}\right) \cdot \cos\left(\frac{(\omega_1t-k_1x)-(\omega_2t - k_2 x)}{2}\right) \right]\\ s &= 2s_0 \left[ \sin\left(\frac{\omega_1 + \omega_2}{2} t - \frac{k_1 + k_2}{2} x\right) \cdot \cos\left(\frac{\omega_1 - \omega_2}{2} t - \frac{k_1 - k_2}{2} x\right) \right]\\ s &= 2s_0 \left[ \sin\left(\overline \omega t - \overline{k} x\right) \cdot \cos\left(\frac{\Delta \omega}{2} t - \frac{\Delta k}{2} x\right) \right]\\ \end{split} $$
Here, $\overline \omega$ is larger than $\Delta \omega$ and this is why:
- $\scriptsize\sin \left(\overline{\omega}t - \overline k x\right)$ is the part which declares an envelope and
- $\scriptsize\cos \left(\frac{\Delta{\omega}}{2}t - \frac{\Delta k}{2} x\right)$ is the part which declares phases inside an envelope.
Then, the professor takes only the part which declares an envelope and says that the phase of this part must be constant, like this:
$$ \scriptsize\frac{\Delta{\omega}}{2}t - \frac{\Delta k}{2} x = const. $$
QUESTION: What does this mean? Does a constant phase mean to only look at one point which is always at the same distance from the $x$ axis?
The professor then goes on to derive the group velocity like this:
$$ \scriptsize \begin{split} \frac{\Delta{\omega}}{2}t - \frac{\Delta k}{2} x &= const.\\ \frac{\Delta k}{2} x &= \frac{\Delta{\omega}}{2}t - const.\\ x &= \frac{\Delta{\omega}}{ \Delta k} t - \frac{2}{\Delta k}const.\\ \end{split} $$
If I partially differentiate $x$, I finally get the group velocity:
$$ \scriptsize \begin{split} v_g &= \frac{\partial x}{\partial t} \\ v_g&= \frac{\Delta{\omega}}{ \Delta k}\\ v_g&= \frac{\textrm d{\omega}}{ \textrm d k} \end{split} $$
