Just a short question about the vertex factor in QFT. When I have an interaction Lagrangian
$$\mathcal{L}_{\mathrm{int}}=-\frac{\lambda}{3!}\phi^3$$
with a real scalar field $\phi$, is the vertex factor given by $-i\lambda$ or $-i\frac{\lambda}{3!}$?
Because as far as I learnt, the vertex factor is $-i\frac{\lambda}{3!}$ and $3!$ is the symmety factor of the diagram. But I saw in many books that they claim that $-i\lambda$ is the vertex factor of this interaction.....
It is conventional to write interactions normalized by the number of permutations of identical fields. So, there will be a $\frac{1}{n!}$ factor for each interaction with $n$ identical fields. This factor is then canceled by the $n!$ ways of permuting the $n$ identical lines coming out of the same internal vertex.
The diagram is therefore associated with just the prefactor, e.g. $\lambda$, from the interaction.
If the diagram presents a symmetry, you have also to divide by the geometrical symmetry factor.
It seems that OP is not questioning the standard convention to divide each term in the Lagrangian with its symmetry factor, e.g., $${\cal L}~=~-\frac{1}{2}\partial^{\mu}\phi\partial_{\mu}\phi -\frac{1}{2}m^2\phi^2 - \frac{\lambda}{3!}\phi^3.$$ Rather OP is assuming the above standard convention, and asks if the vertex factor$^1$ is $-\frac{i}{\hbar}\lambda$ or $-\frac{i}{\hbar}\frac{\lambda}{3!}$? The answer depends on context:
  1. On one hand, viewing the 3-vertex as an amputated Feynman diagram (say, as the leading contribution to the 1PI 3-point vertex function), the vertex factor is $-\frac{i}{\hbar}\lambda$. An amputated Feynman diagram is typically stripped of the symmetry factor of the external legs because the legs are distinguishable -- they carry different momenta for starters.
  2. On the other hand, e.g. in the source picture $$\phi\quad\longrightarrow\quad\frac{\hbar}{i}\frac{\delta}{\delta J} ,$$ where interaction terms $$ -\frac{i}{\hbar}\frac{\lambda}{3!}\phi^3\quad\longrightarrow\quad-\frac{i}{\hbar}\frac{\lambda}{3!}\left(\frac{\hbar}{i}\frac{\delta}{\delta J}\right)^3$$ are differentiating propagator terms $\frac{i}{2\hbar}J\Delta J$ to build Feynman diagrams, the vertex factor is $-\frac{i}{\hbar}\frac{\lambda}{3!}$. For the source picture, see eq. (3) in my Phys.SE answer here.
References:
  1. M.E. Peskin & D.V. Schroeder, An Intro to QFT, 1995; first paragraph on p. 93.
$^1$ We have restored the factors of $\hbar$.
