I recently read Emperor's New Mind, by Sir Roger Penrose. In it he talks at length about "determinism" in science.
How does the Uncertainty Principle bring about the notion of so called indeterminism, in the sense that how do we know it is a fundamental law of nature that doesn't allow us to make certain observations, unlike the average Newtonian chaotic system (turbulent flow of fluids and the like) which is labelled deterministic chaos and not regarded as a fundamental principle?
Edit : I got interested (also confused) towards this question after reading G 't Hooft's SE question and subsequent responses.
Maan
  • 1,784
6 Answers6
The Heisenberg uncertainty principle reflects the fact that, according to quantum mechanics, certain combinations of the observable properties of particles are fundamentally incompatible (the technical term is 'non-commuting'), so that the particle cannot posses both properties at once. If a particle has a definite position say, its momentum is undefined. Conversely, if a particle has a definite momentum its position is undefined. There is no exact classical analogy, but you might consider, for example, the viscosity of liquid water and the shear strength of an ice crystal. They are both properties of water, but they are not properties that any given volume of water can possess simultaneously.
Quantum mechanics says that if you make a measurement of one property of a particle, and then make a measurement of another property that does not commute with the first, the result will be unpredictable, although there is a rule (the Born rule) which allows you to calculate the relative probabilities of one result compared to any other. It is the unpredictable nature of this effect which makes for an indeterministic outcome.
The effect is quite different in principle from classical chaos.
In this context how does the Heisenberg Uncertanity Principle
Physics is the discipline that uses mathematical models, called Physics Theories, to describe observations and data, and, very important to predict future behavior. (A model that only fits existing data is a map, not a theory). So quantum mechanics, the theory developed from observations and measurements, has introduced indeterminacy because it is necessary to describe the data.
It was found that the differential equations that describe wave functions can be used to model the observations and data, if extra axioms pick up the correct solutions that can be descriptive and predictive of data. Principles, laws, postulates are the names used for these axiomatical statements. The Heisenberg Uncertainty Principle (HUP) was deduced from data that were incompatible with the microscopic world, where mostly the new quantum theory is needed, can be shown to emerge from the commutation relations of the complicated theory of Quantum Mechanics.
bring about the notion of so called indeterminism ,in the sense that how do we know it is a fundamental law of nature
In the final theory, the indeterminacy comes from the wavefunction postulate
$Ψ(x,t)$ = single valued probability amplitude at $(x,t)$
$Ψ^*(x,t)Ψ(x,t)$ = the probability of finding the particle at $x$ at time $t$ provided the wave function is normalized
This is what makes for the basic indeterminacy in quantum mechanics, and the theory was developed in order to explain the data of that time: photoelectric effect, black body radiation, spectra of atoms. It prevailed because it was predictive of new data.
that doesn't allow us to make some observations and unlike the average Newtonian chaotic system (turbulent flow of fluids and the like) which is labelled deterministic chaos.
The concept of probability in both classical mechanics and quantum mechanics is the same, the same with the simple probabilities of throwing a dice.
In classical deterministic chaos dealing with the many particle states, it is the complexity of the enormous number of particles that displays an emerging chaotic behavior, inability to exactly determine individual particle tracks. Quantum mechanics, by identifying particles with a probability distribution are inherently non deterministic. There are theoretical efforts to define an underlying deterministic layer of physical quantities from which the indeterminacy of quantum mechanics emerges, but they are not successful up to now, that is another long story.
anna v
  • 236,935
Just because it didn't pop up yet, I wanted to add something for completion. Some answers and comments claimed that classical chaos arises because there is no way of telling exactly what a particle's trajectory is because of the complexity of the system. This isn't really the essence of classical chaos.
Chaos Theory
Equations of motion are relations between initial conditions and final states after some time. Mathematically, these relations can be expressed by maps: starting from an initial state $X_{0}$ at time $t = 0$, one can ask what the state $X_t$ at time $t > 0$ is. Experience tells us that there is but one state at time $t$, so yes, we are talking about a family of maps $\Gamma_t$ that take $X_0$ into $X_t = \Gamma_t(X_0)$ (notice that we already assumed time translation invariance). The properties of this map are clearly of mathematical and physical interest. One very basic property of a map is its continuity (let's just assume we have some notion of topology on the space of states).
A very brief and incomplete definition of chaos theory is the study of dynamical systems where the map $\Gamma_t$ is discontinuous. This is best understood by an example. If you throw darts at a target, and hit the target just a few millimeters below the bull's eye, you will try to imitate your previous shot as perfectly as possible, maybe just aim a wee bit higher. This is because you assume there is a continuous relation between the initial conditions (the way you hold and throw the dart) and the final state (where you hit the target). However, this does not hold true when you analyze the weather, where chaos theory was discovered and why everyone loves talking about insects that cause weather catastrophes by just doing what they do (probably also why that weird "The Butterfly Effect" movie was made. Spoiler: Not much physics in that one.).
The root of chaos is colloquially considered to be nonlinearities (which, right behind infinities, are probably the number two cause of death for well-behavedness in mathematical models). Not all nonlinear systems are chaotic, but you can't get chaos without it. As you can easily verify with your classical mechanics knowledge, classical mechanics permits nonlinear equations of motion. Anything that's not the harmonic oscillator (or some rip-off thereof) is nonlinear. A prominent example of a nonlinear classical set of equations are the Navier-Stokes equations, and turbulence happens exactly when the nonlinear terms in the equations of motion (the $(\mathbb{v}\cdot \nabla)\mathbb{v}$ term) become relevant.
Note however that this is not the same as indeterminism. In principle, the mathematical equations allow you to start at an initial state and get to the unique final state that starts at the initial state and adheres to the equations of motion through the dynamical evolution. It is true that this determinism is quite useless: Whenever we measure a system, our measurement has a finite accuracy. That is, we know that the state variables of the system are around certain values, but not exactly those values. If we were to use the initial condition that our measurement provided, a chaotic system may take us to some very different point in state space than the actual evolution of the system, because the measured values differ from the actual values and the non-continuous time evolution takes us to a completely different place in state space.
It is therefore common and well-justified to not bother with the exact nature of state space trajectories. Rather, one looks for other defining features of the system beside the points that a trajectory may or may not pass through. One could say that probability theory is used as a means to consider multiple trajectories simultaneously, but it's not the only viable option at this point.
Quantum Indeterminism
Much has been said about quantum indeterminism in the answers already. I just want to point out a fine interesting difference: In non-relativistic Schrödinger QM, the time evolution is unitary. That is, the time evolution map is a linear operator that does not change the length of a vector. This means that this map is continuous (an operator with a finite norm is continuous. Leaving aside compactness here, maybe that will be a problem). From this argument, the unitary time evolution in the Schrödinger equation does not allow for chaos (remember, nonlinearity is a crucial ingredient to chaos). The indeterminism is therefore at a different level. It turns out that QM requires some further postulates to connect states to measurement results, the states can not be directly measured (as opposed to classical mechanics). We cannot give anything better than stochastic relations for the state-measurement-connection. Some are discontent with probabilistic laws at the fundamental level of physics, they believe that there are additional ingredients to the state-measurement connections, we just can't measure them in experiments yet (those are Hidden-Variable theories. They follow Einstein's requirement that God doesn't play dice). There are others who are willing to accept probability at the root of physics, but they also don't agree on how and where exactly probability enters the game (they follow Bohr's reply to Einstein, which was roughly: Stop telling God what to do!).
This discrepancy between states and measurable data is, to my mind, at the root of quantum indeterminism. There are many ways in which it pops up, definitely not restricted to non-relativistic QM, and some are formulated as uncertainty principles and the like. But this seems to me to be the core issue.
TBissinger
  • 1,346
The HUP is fully compatible with determinism. Quantum mechanics without any special role for measurement (i.e. with the Schrodinger equation as the only law of motion) is deterministic, for example.
WillO
  • 18,387
Uncertainty (heisenberg) is a consequence of intrinsic wavelike nature of positions and velocities of particles in the physics model called quantum mechanics.
It is quite fundamental but not necessarily most fundamental since QM is certainly not the most fundamental theory/ model. That's not to say I'd doesn't predict things, it actually makes some of the most precise predictions in all of physics. The things that can't be determined / predicted by QM might be able to be determined by a more fundamental theory.
The only certain fundamental limit of determinism is that of local determinism, meaning that there will be some uncertainty based only on local information like for example in the case of quantum spin which is non local / requires faster than light interaction.
Kugutsu-o
  • 874
-2
Einstein didn't believe in the (statistical) Copenhagen interpretation of QM. Me neither. He believed in hidden variables, which are pretty hard to find if they are hidden. But what is hidden can be uncovered. I think they are not covered and can be found all around an inside of us: Spacetime! But then again what is spacetime?
In the case of chaos, one leaves from the (Newtonian as you call it, which I doubt) principle that the trajectories of the particles are fixed and not connected with QM. Are you MAAN in the sense of MOON?
Deschele Schilder
  • 45
  • 105
