Let us assume that we know only some basic QM notions which are part of the Heisenberg picture of quantum mechanics and Dirac quantization
- Physical observables are represented by Hermitian operators $\hat{O}$, which generally do not commute
- $[\hat{x},\hat{p}]=i$ , the commutation relation between momentum and postion
- The existence of a Hamiltonian operator $\hat{H}$ such that $$\frac{d}{dt}<\hat{O}>=\left<i[\hat{O},\hat{H}]\right>$$ where $<...>$ is a probabilistic expectation.
Note that we do not know how to obtain what $<...>$ is, only its equation of mootion. But its enough to completely solve, fo instance, the simple harmonic oscillator, and from this obtain both the notions of intrinsic uncertainity of position and momentum and quantization of energy level.
From this and also notions of representation theory, hermiticity, and other strictly mathematical properties of operators as well as usual properties of probabilistic averages, can one prove that a "density" observable exists, $\hat{\rho}$ such that for any other observable $\hat{O}$, $$<\hat{O}>=Tr \left( \hat{O}\hat{\rho}\right)$$
The reason I am asking is, the above setup is, at least to me, very physically intuitive (measurements do not commute so you represent them by operators, and so on) and free of the usual apparently arbitrary and paradoxical notions associated with QM (wavefunction collapse and so on). If the existence of the density matrix can be understood this way, it would be easy to continue with usual Eigenvalue and EigenVector notions to construct the wavefunction as a generic basic for the density matrix, and derive the rest of quantum mechanics from this. It would be, in my opinion, the way to introduce quantum mechanics with the least amount of philosophical mumbo-jumbo. However, it relies on the density matrix following from the above assumptions, and I was not able to prove it or find such a proof (a kind of reverse Gleason's theorem). Do you think this is doable?
