-1
Considering that I've never studied quantum mechanics before I have need to understand the operator commutator. My start is: $[A,B]=AB-BA \tag{a}$
Now, why must be
$$\left[\frac{\partial }{\partial x},x\right]\stackrel{?}{=}1 \tag{1}$$ I have thought, from the rule (a),
This identity $$\left[x,\frac{\partial }{\partial x}\right]=-1 \tag{2}$$ is easy because $[A,B]=-[B,A]$. I have not understood, also, (3) and (4) $$\left[i\hslash\frac {\partial}{\partial x},x\right]=i\hslash \tag{3}$$
$$[p_x,x]=i\hslash \tag{4}$$ where $p_x$ is the momentum on $x-$ axis.
Sebastiano
  • 2,681
Equations (a), (1), (2), (3) and (4) all are operator equations. Therefore you need to understand what an operator equation actually is.
Now, why must be $$ \left[\frac{\partial }{\partial x},x\right]\stackrel{?}{=}1 \tag{1}$$
That means, the operators on the left-hand-side and on the right-hand-side always yield the same result when applied to arbitrary functions.
Hence, here you must prove that $$ \left[\frac{\partial}{\partial x},x\right] \psi(x) = 1\cdot \psi(x) $$ for every function $\psi(x)$.
The proof is a long sequence of very elementary steps: $$\begin{align} &\left[\frac{\partial }{\partial x},x\right] \psi(x) \\ = &\left(\frac{\partial}{\partial x} x - x \frac{\partial }{\partial x}\right) \psi(x) \\ = &\frac{\partial}{\partial x} x \psi(x) - x \frac{\partial }{\partial x} \psi(x) \\ = &\frac{\partial x}{\partial x}\psi(x) + x \frac{\partial \psi(x)}{\partial x} - x \frac{\partial \psi(x)}{\partial x} \\ = &\frac{\partial x}{\partial x}\psi(x) \\ = &1\cdot \psi(x) \\ \end{align}$$
Okay, I'll try to answer.
First of all, there's one idea that some people forget at the beginning: commutators are operators
That is, they act on a wavefunction, like all operators.
A commutator is something that needs an input of two operators: $A$ and $B$, and the output is another operator, which is $(AB-BA)$. That is an operator.
For me, it is dangerous to write $[\frac{\partial}{\partial x} , x] =1$, because a commutator is not a number. That "number 1" refers to the "operator one", or the identity operator. I prefer writing
$$\left[\frac{\partial}{\partial x} , x\right] =\mathbb{I}$$
What's more, it is better to write capital letters, or hats on the letters, because here $x$ is not a variable, it is the $X$ operator. We should write:
$$\left[\frac{\partial}{\partial X} , X\right] =\mathbb{I}$$
And this is important because this reminds you that operators make sense when they are applied on wavefunctions.
So, if you want to evaluate $[X, P_x]$, by definition, it is $X\ P_x - P_x\ X$
But this makes sense when you apply it to a wavefunction, that is, you should take an arbitrary wavefunction $\psi$ and compute
$$[X, P_x]\psi=X\ P_x \psi - P_x \ X\ \psi =X\ (P_x \psi) - P_x \ (X\ \psi) $$
And that's how you prove the different relations.
You have to know how each operator acts on the wavefunction. For example $X\psi = x\psi$, it is just multiplying it by the $x$ variable.
However, the way $P$ acts is $P\psi = -i\hbar \frac{\partial \psi}{\partial x}$
So, in sum, you demonstrate commuting relations by appliying them to an arbitrary $\psi$.
FGSUZ
  • 8,573
A nice and simple proof can be found in Introduction to Quantum Mechnics by David J. Griffiths, section 3.5. This book is a classical introductory book to quantum mechanics.
Basically, for any observable A, you have $\sigma_A^2 = \langle (\hat{A} - \langle A \rangle) \Psi | ((\hat{A} - \langle A \rangle ) \Psi \rangle$, from which it shown in the book that $$\sigma_A^2 \sigma_B^2 \geq \left(\frac{1}{2i} \langle [\hat{A}, \hat{B}] \rangle \right) .$$
Now you had the correct idea to calculate the commuator, but to see it correctly, you need to apply it to a test function, say $f$. Then, the derivative acts according to the product rule, that is $$ [i\hbar \frac{\partial}{\partial x}, x]f = i\hbar \frac{\partial}{\partial x} xf - x \frac{\partial}{\partial x}f = i\hbar f + i\hbar x \frac{\partial f}{\partial x} - i\hbar x \frac{\partial f}{\partial x} = i\hbar f. $$ Thus, as an operator, $[\hat{p}_x, \hat{x}] = i\hbar \mathbb{1}$ where $\mathbb{1}$ is the identity which you can ignore.
gingras.ol
  • 766
  • 15
