Define a single-particle Green's function as \begin{equation} i\hbar G(xt;x't') = \langle x| e^{-iH(t-t')/\hbar} | x'\rangle. \end{equation} By inserting the completeness relation, we have \begin{equation} i\hbar G(xt;x't') = \sum_n \langle x|n\rangle \langle n| x'\rangle e^{-iE_n(t-t')/\hbar}, \end{equation} where $|n\rangle$ and $E_n$ are the eigenstates and eigenvalue of the Hamiltonian $H$. By using the Fourier transform, the Green's function in the energy domain can be calculated as \begin{equation} \begin{split} G(x,x';E) &= \int_{-\infty}^{\infty} G(xt;x't') e^{iE(t-t')/\hbar} dt\\ &= \frac{1}{i\hbar}\int_{-\infty}^{\infty} \left\{ \sum_n \langle x|n\rangle \langle n| x'\rangle e^{-iE_n(t-t')/\hbar} \right\} e^{iE(t-t')/\hbar} dt\\ &= \frac{1}{i\hbar}\sum_n \langle x|n\rangle \langle n| x'\rangle \int_{-\infty}^\infty e^{i(E-E_n)(t-t')/\hbar} dt\\ &= -2\pi i\sum_n \langle x|n\rangle \langle n| x'\rangle \delta(E-E_n) \end{split} \end{equation} However, from my knowledge, $G(x,x';E)$ is usually defined as \begin{equation} G(x,x';E) = \sum_n\frac{\langle x|n\rangle\langle n| x'\rangle}{E - E_n}. \end{equation} So my question is how can the above two equations be related? Or is there anything wrong with my derivation?
Both are correct, but are different quantities.
The latter is the (Fourier transform of the) retarded Green's function $G_R$. It is related to your "Green's function" (which really is a kernel) $G$ through
$$ G_R(x,t; x', t') = \frac{1}{i\hbar}\Theta(t-t')G(x,t; x',t') $$
See this wonderful answer about kernels, propagators and Green's functions.
Nephente
  • 3,376
