Quantum tunneling is a QM phenomenon where the subatomic particle passes through the potential barrier.
In quantum mechanics, the rectangular (or, at times, square) potential barrier is a standard one-dimensional problem that demonstrates the phenomena of wave-mechanical tunneling (also called "quantum tunneling") and wave-mechanical reflection. The problem consists of solving the one-dimensional time-independent Schrödinger equation for a particle encountering a rectangular potential energy barrier. It is usually assumed, as here, that a free particle impinges on the barrier from the left.
https://en.wikipedia.org/wiki/Rectangular_potential_barrier
Now there is a classical interpretation.
Although classically a particle behaving as a point mass would be reflected, a particle actually behaving as a matter wave has a non-zero probability of penetrating the barrier and continuing its travel as a wave on the other side.
This means that as per QM, the particle behaving as a wave can actually exist at some probability on the other side of the barrier.
In classical wave-physics, this effect is known as evanescent wave coupling. The likelihood that the particle will pass through the barrier is given by the transmission coefficient, whereas the likelihood that it is reflected is given by the reflection coefficient. Schrödinger's wave-equation allows these coefficients to be calculated.
So there is a way to do this in the classical way, using evanescent wave coupling.
Especially in optics, evanescent-wave coupling refers to the coupling between two waves due to physical overlap of what would otherwise be described as the evanescent fields corresponding to the propagating waves.[7]
One classical example is frustrated total internal reflection in which the evanescent field very close (see graph) to the surface of a dense medium at which a wave normally undergoes total internal reflection overlaps another dense medium in the vicinity. This disrupts the totality of the reflection, diverting some power into the second medium.
https://en.wikipedia.org/wiki/Evanescent_field#Evanescent-wave_coupling
