On pg 104 of "Introduction to Quantum Mechanics" by Griffiths, we are asked to find the eigenfunctions of the $x$ operator. Hence, we have to find functions such that $$x f(x)=\lambda f(x)$$ I have used the notation $\lambda$ instead of $y$ because it is less confusing for me. Clearly, any function that satisfies $f(x)=0$ for $x\neq \lambda$ will be an eigenfunction. However, Griffiths claim that the only eigenfunction is $\delta(x-\lambda)$. Why is this true?
Ryan Hendricks
  • 189
Here is a formal wisecrack to reassure you: work in momentum space.
Up to normalization constants that do not matter that much for your un-normalizable wave function, consider $$ f_\lambda (x)=\langle x| f_\lambda\rangle= \int dp \langle x|p\rangle \langle p|f_\lambda\rangle = \int \frac{dp}{\sqrt{2\pi \hbar}} e^{ixp/\hbar} \langle p|f_\lambda\rangle ~. $$
Now your strarting point was $$ \hat x | f_\lambda\rangle = \lambda |f_\lambda \rangle , $$ and the momentum representation of $\hat x$ is but $$ \hat x= \int dp ~|p\rangle ( i\hbar \partial_p )\langle p| ~, $$ so that $$ \int dp ~|p\rangle ( i\hbar \partial_p )\langle p|f_\lambda\rangle =\lambda |f_\lambda\rangle.$$
Multiply on the left by $\langle p'|$, collapse the δ-function, and relabel p' to p, to get $$ i \hbar \partial_p \langle p|f_\lambda\rangle= \lambda \langle p|f_\lambda\rangle. $$
You may solve this by $$ \langle p|f_\lambda\rangle \propto e^{-i \lambda p/\hbar } , $$ readily leading to your $$ f_\lambda (x)= \int \frac{dp}{\sqrt{2\pi \hbar}} e^{i(x-\lambda) p/\hbar} \propto \sqrt{\hbar }~~\delta (x-\lambda) ~. $$
Dirac, sublimely slyly, all but does something equivalent in his book, on the basis of his magnificent standard ket, the translationally invariant momentum-space ket. I reckon Griffiths should be more humble in his implicit characterizations there.
Cosmas Zachos
  • 67,623
