-3
If I make no mistake, dynamic viscosity $\eta$ is measured in $ \rm kg /(s\, m) $. And volume is measured in $\rm m^3$.
The product of the two has the same units of Planck's quantum of action $\hbar$, namely $ \rm kg\, m^2 /s $. Does this mean that there is a uncertainty relation between volume and viscosity?
I have not found anything of the kind in the literature; however, usually, two quantities whose product has the units of $\hbar$ follow a uncertainty relation, such as position and momentum, phase and angular momentum, or energy and time.
So the question is: is there a relation of the type
$$ \Delta \eta \, \Delta V \geq \hbar \ \ ?$$
This is a question about the measurement precision of physical observables: can the simultaneous measurement of the viscosity and the volume of a fluid have measurement errors that are independent of each other and can be a small as desired?
If no such relation existed, then the right hand would be zero, and then it seems that it should be possible to circumvent the usual uncertainty relation between momentum and position.
tpg2114
  • 16,815
frauke
  • 704
The fact that the dimensions of two given variables multiply into those of action is by no means sufficient for there to exist a theory where they are canonical conjugates.
Viscosity, in particular, is extremely unlikely to find any sort of a home in a quantum mechanical framework. For one, viscosity reflects a dissipative process, and those are extremely hard to fit into QM. For another, quantum fluids are, generically, superfluids, with no viscosity.
There's nothing specific that says that this coupling is forbidden, but there's no requirement for it and you're unlikely to find one.
As for this,
That's a remarkable leap of logic with nothing to back it up.
Emilio Pisanty
  • 137,480
